Ignition switch?!?!
Old 19 May 2014, 07:23 pm
Default Ignition switch?!?!
I don't own a Cruiser but I'm trying to help my sister out. She has a 2006 non Turbo, that didn't want to start but all lights turn on just fine. Battery is good, had the starter test and it's good too, but what I did find out was that if I turn the key forward and back a couple of times quickly the car WILL TURN ON. This leads me to believe that it can be the switch itself. I've looked all over the net and can't find anything that answers my question so I'm hoping someone here can help me out. Everything and anything will be greatly appreciated.
Old 19 May 2014, 07:52 pm
Default Re: Ignition switch?!?!
Possibly, but I would suspect the battery cable. Mine did the same thing and despite all the grounds being very clean, mine acted like yours. I did replace the ignition switch since it was cheap and an easy install, but it didn't work. Replace the cables.
Old 19 May 2014, 08:09 pm
if she is still paying for the car ask her if she has made any recent payments and if she says she is late on one, better hide the car because the repo is coming to getcha lol
Probably just a bad actuator pin
Old 19 May 2014, 08:12 pm
I cleaned the battery posts good, and put new terminals also but did not try the entire cables. Since you said that you did swap out the switch I'm curious about something else. Hers has the transponder key, when you replaced it were you able to install any switch or did you also have to buy the keys and have it programmed?
Old 19 May 2014, 08:36 pm
you mentioned that they checked the starter and worked but did you also check the relay?
Old 19 May 2014, 09:47 pm
I took the starter out and had an auto parts store test it, I saw it start up fine, did the test 3x. I did not check the relay, where exactly is it located? Since my brother in law is the manager to the parts store I have no problem trying things out and returning them if it's not the problem lol
Old 19 May 2014, 10:17 pm
usually located in the PDC ( power Distribution Center) and that box is located behind the air box
I cant remember which relay is it but in the PDC cover it should tell you the relay location all you have to do is swap the starter relay with the horn relay and if the starter relay is bad your starter will now work but the horn will not xD
Lolo376 likes this.
Old 19 May 2014, 10:20 pm
found it here it is
just swap the horn relay with the starter relay and check if it works now
Old 19 May 2014, 10:24 pm
randyincctx's Avatar
Lightbulb Re: Ignition switch?!?!
Your problem lies in the ignition cylinder,ignition switch actuator pin,or the ignition switch........If I was in Vegas,I'd put my money on the ignition switch actuator pin(fairly common problem);I'm basing that on the way you describe it working by quote: 'if I turn the key forward and back a couple of times quickly the car WILL TURN ON.'
There's probably still enough of the actuator pin left to allow it to work like that sometimes,but it is just a matter of time before even that trick won't work anymore.
The actuator isn't all that expensive($30-$35 +/-),and it's a really,really easy fix(as the video I posted shows!)
Aka:~KILLER~
Old 19 May 2014, 10:28 pm
Oh wow sorry lolo376 my mind whent floating for a while and lost track my bad, yeah like I said on the third post it might just be the actuator pin
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
possible ignition switch problem skisbabe Tech & Performance Forum 3 02 Oct 2012 01:41 pm
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
