04 not firing on 1 and 4
Old 21 May 2014, 09:54 am
Default 04 not firing on 1 and 4
I have replaced the coil pack, plugs, wires and ignition switch and the problem continues. I get error code p2302. It has been like this since October and I find the same problem when I search the web but no answers. I am a new member and searched this forum but I couldn't find any thing. Please help!
Old 21 May 2014, 10:09 am
Default Re: 04 not firing on 1 and 4
Does it run at all?
Have you checked for spark?
If you have spark, next things to do would be an injector test and a compression test.
How many miles?
Old 21 May 2014, 12:06 pm
Ray_Dockrey's Avatar
Read thru this:
2003 PT warms up then spits and sputters.
Old 21 May 2014, 12:39 pm
randyincctx's Avatar
Post Re: 04 not firing on 1 and 4
Here is a online post for a 2005 PT Cruiser that was experiencing the very same issue,you may be able to follow it to find the ultimate solution:
http://www.justanswer.com/chrysler/2...1-4-spark.html
Aka:~KILLER~
Old 29 May 2014, 09:35 am
I had the same problem with my 04 PTC and it said I need a new coil pack
After changing the sparkplugs, wires, coil pack, cam sensor and crankshaft sensor the guys at Firestone discovered the the PCM (on the firewall/computer) was bad and they replaced it for free.
You cannot take one from a junk car and replace it w/a bad one, you have to go to a company that sells them, there is one in Ft. Lauderdale, you can look it up on google for about $ 150.00 and they have to program it to your VIN number.
This was an ongoing problem for 2 years and it is now fixed but I am stuck with a bit of a vibration in the motor at idle after replacing the motor mounts and trans mount
Old 29 May 2014, 09:56 am
Ptdave02's Avatar
Ignition Coil No. 1 Secondary Circuit Insufficient Ionization
Trouble Code Conditions:Engine started; and the PCM detected the Ignition Coil No. 1 secondary "burn time" was insufficient, or it was missing.
Possible Causes:
•Intermittent condition
•Cylinder No. 1 spark plug or wire is damaged or it has failed
•Ignition Coil No. 1 is damaged or it has failed
•Ignition coil control circuit is open or shorted to ground
•ASD relay output circuit problems
•PCM has failed
Old 29 May 2014, 10:44 am
you should add your location to your profile and some info about your car(year/trim/trans) to your signature. if you were near me with a compatible car, i'd let you try my ECU.
Old 29 May 2014, 11:36 am
cruserdad1976's Avatar
When you replace the wore out motor mounts with new FRESH ones you will usally feel a little more of the motor viberation espically if you go to the better ones
Number 1 not firing off coil cleven General PT Cruiser Discussions 6 12 Sep 2013 09:31 am
Not Firing Koseck Tech & Performance Forum 3 20 May 2013 02:45 am
Please help again - Sputtering and Back firing clickhere4dawn Tech & Performance Forum 10 23 Nov 2012 11:25 am
2002 PT Cruiser not firing fletch65 Tech & Performance Forum 28 20 Apr 2011 09:46 am
Miss firing code cyl 4 devil9 Tech & Performance Forum 3 04 Jun 2010 09:36 am
