Will new banjo fitting fit updated turbo oil feed line?
Old 22 May 2014, 03:43 pm
Default Will new banjo fitting fit updated turbo oil feed line?
i went to mopar direct today, and called turbos unleashed at same time to confirm info, the guy told me that 2005 turbo, they made a new style oil line as they were having a lot of issues with stock ones at that time, and that with buying new oil line I need this new banjo fitting, but he wasn't sure if banjo fitting would fit my car? that's what threw me off, he had all this knowledge ,and was right, cause the part numbers he gave me, were the replacement parts from mopar, so that banjo has to fit right?? if anyone knows what i'm talking about here chime, in and put me to ease, he also said I don't need to use those 4 copper crush washers with new setup? that doesn't make sense either as there on bolts aren't they??
heres the supposed new updated oil feed line for a 2005 h.o. pt cruiser gt
part #4884276AD
Factory Oil Supply Line PT Cruiser and SRT-4
and here's the banjo fitting, and these were the same numbers at mopar so I ordered there.
Part#6036517AA
Turbo Oil Feed Line Fitting 6036517AA
thanks guys, what about those 4 crush washers?
2005 PT CRUISER GT
Semper Fidelis!!!
Old 22 May 2014, 09:06 pm
Default Re: Will new banjo fitting fit updated turbo oil feed line?
There is no banjo fitting on the oil lines. Those are on the coolant lines.
Old 22 May 2014, 09:36 pm
well I have those 2 parts coming and on the screen at Chrysler it did say that fitting was for oil? soo we'll see I guess
2005 PT CRUISER GT
Semper Fidelis!!!
Old 22 May 2014, 10:01 pm
Here is one of your banjo fittings. Coolant lines.
Old 24 May 2014, 10:11 pm
I see that, is that where the 2 copper crush washers go, one before screw and other after? also I was referring to fitting above, but alls well I received parts today from mopar and it all fits, the oil feed is so small online it looks like 3 feet or more, I was surprised to see a 12' or so line, lol, but I heard they crud up and fouled up so 40 well spent I think, obviously you know a thing or two, should I put on the 3' o2 sensor housing pipe, its like a twisted 45 degree pipe, weird angle, im sure you know exactly which I mean. now that turbo's out, and is it easier to remove when turbos out, I can remove whole exhaust including down pipe actually, as im changing this week as well 3' down 2.5 magnaflow all out, just wondering when it was easiest to that that job, with turbo in or out, thanks
2005 PT CRUISER GT
Semper Fidelis!!!
Replacing turbo oil feed line Strilla Turbo Performance 3 30 Dec 2013 02:53 pm
Oil feed line leak to turbo PTCruisinTurbo General Turbo Discussions 1 30 Dec 2013 01:31 pm
Turbo oil feed line replace...HELP golf55555 General Turbo Discussions 3 30 Dec 2013 01:17 pm
Turbo oil feed/supply line mole General Turbo Discussions 5 07 May 2013 12:15 am
oil feed line help!! jeffyboy General Turbo Discussions 3 12 May 2011 02:13 pm
