2006 PT shaking when idling with AC
Like Tree2Likes
  • 2 Post By PT_Patriot
Old 23 May 2014, 03:09 pm
Angry 2006 PT shaking when idling with AC
Last week my PT started shaking every few seconds when idling with AC on. Always giving cold air but when idling it almost feels like it's struggling and revving up a little. Once I'm moving it's fine. Last night the engine light came on. Anything I can do to try and solve this? The mechanics wont be able to see me until Tuesday.
Old 23 May 2014, 03:25 pm
Default Re: 2006 PT shaking when idling with AC
Sounds like the radiator fan isn't working. Search this forum and you will find a wealth of information about this well known problem and ways to troubleshoot it.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
Old 01 Jul 2014, 06:54 pm
Thumbs up Re: 2006 PT shaking when idling with AC
Update: I could see that may fan was working and I always had cold air even when idling with the shaking every couple of seconds. I read a thread here where the gentleman performed a tune up and that fixed his problem. I went a head and got a tune up since it was due anyway. That did not stop the shaking but the mechanic tested my battery while I was there and informed me that I needed a new one. (FYI I did not mention the shaking, I was just there for a tune up) So I went back and got a new battery. Problem Fixed NO MORE SHAKING WHILE IDLING WITH THE AC ON.
Old 01 Jul 2014, 07:13 pm
Shaking cured when a new battery fitted? That's one for the books but I doubt we'll be passing that along to anyone else with shaking at idle with the A/C. I'd ask the mechanic what he happen to do besides change the battery that might have helped with the shaking.
Old 01 Jul 2014, 08:08 pm
I'm thinking that the draw of the A/C combined with heavy draw from alternator (to charge low battery) was the cause of a heavy load on engine.
Old 01 Jul 2014, 08:12 pm
Ray_Dockrey's Avatar
If you are there for a tune up why would he check the battery other then to try and sell you something you didn't need. I agree with Crewzin. I wonder if he found a vacuum line loose or broke while replacing the battery.
Old 03 Jul 2014, 01:11 pm
could be the IAC Valve or just the hose going to it?
Old 04 Jul 2014, 07:10 am
Re-reading the post - it seems likely that the tune-up - (I assume tune-up = new wires and plugs) - is what cured the shaking.
Old 04 Jul 2014, 08:01 am
Originally Posted by Carre832 View Post
Update: I went a head and got a tune up since it was due anyway. That did not stop the shaking but the mechanic tested my battery while I was there and informed me that I needed a new one.
Don, I would have thought so too but then he said the above and I ruled that out.
Old 04 Jul 2014, 08:31 am
Oh well, at least he's fixed....
Idling Problems Budman1 Tech & Performance Forum 10 13 May 2013 09:05 am
Idling Hesitation Ken Swenson Tech & Performance Forum 17 25 Feb 2013 04:50 pm
almost dies while idling chaoscow Tech & Performance Forum 19 16 Feb 2013 02:48 pm
01 PT Idling too low xebix Tech & Performance Forum 4 30 Jun 2012 09:12 pm
Idling issues FatalFurr Tech & Performance Forum 4 06 Apr 2010 09:17 am
