2007 2.4 non turbo died at light
  • 1 Post By boonie2
Old 23 May 2014, 05:54 pm
Default 2007 2.4 non turbo died at light
Wife and I have an 07 touring. Gas light came on but the station near us was overpriced so we only put 2 gal in. Leaving there we got about .5mi away and at a stop light the car just died. No symptoms other than not running (so no smoke, odd noises, etc). It will crank just fine but won't catch. Any suggestions? I'm an hour from home. I'm thinking bad gas, just seems like too much of a coincidence. My wife is getting two 5gal gas cans with 89 octane to try to fill it and dilute out the bad gas. Any other suggestions?
Old 23 May 2014, 06:21 pm
Default Re: 2007 2.4 non turbo died at light
What's the mileage on your car? Have you tried to retrieve the codes? I'[m hoping it's not the belt.
Old 23 May 2014, 06:26 pm
Listen for the ticking of the pump as soon as you turn the key on?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 May 2014, 06:27 pm
Haven't checked the codes yet. The way it just died I'm thinking it's the belt. About 121k on it
Old 23 May 2014, 06:41 pm
Belt is a good bet.
To rule out bad gas, get some starting fluid and spray it in intake - if engine coughs, it means belt didn't break (yet).
Old 23 May 2014, 07:19 pm
Originally Posted by quicksilverdon View Post
Belt is a good bet.
So if the belt broke while idling, odds of damage are low, correct?
Old 23 May 2014, 07:23 pm
Yes, but no guarantees...
Old 23 May 2014, 08:50 pm
Pull the eight mm bolts out of the cam sensor and see if the cams rotate while someone tries to start. Dont see any reason to worry about other damage except the covers if the belt wrapped around the sprockets. Bad gas will run rough and still try to start or even still run.
Old 23 May 2014, 10:37 pm
I'll try that tomorrow. Thanks!
Is changing a belt really that tough?
Old 24 May 2014, 05:17 am
boonie2's Avatar
I'd Vote YES its pretty tough No Room to work , from everything i've seen here .. my Cruiser has 113k miles on it .. going to do the belt soon
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
2007 Battery Light StevenW Tech & Performance Forum 4 01 Nov 2013 03:58 am
2007 PT cruiser died, parts replaced, engine codes are gone, but car wont even crank andrewsmith1984 Tech & Performance Forum 9 30 Dec 2012 10:44 pm
died and will not start back 2005 GT Turbo KyTurbo Tech & Performance Forum 4 28 Sep 2012 09:04 am
Pt Jumpy and shakey, and died at a stop light. wesinator General PT Cruiser Discussions 5 14 Apr 2009 06:02 am
turbo died serape General Turbo Discussions 18 05 Jun 2003 01:47 pm
