5 Speed trans removal,, clutch replace info?
Like Tree2Likes
Old 23 May 2014, 10:23 pm
Default 5 Speed trans removal,, clutch replace info?
anyone know of a good link on here about removing and installing the 5 speed trans on my PT..01 model?,,and clutch replacement ..a link would be nice thanks
Old 24 May 2014, 07:31 am
Default Re: 5 Speed trans removal,, clutch replace info?
Here are some links......
http://www.justanswer.com/chrysler/2...iser-2002.html
Old 24 May 2014, 09:00 am
while it's still on the ground, start by loosening the big axle nuts and lug nuts. also remove the battery and battery tray. disconnect the wiring connectors and shift linkage on the trans(i used a visegrip and a small hammer to tap the shifter linkage clips off as they were stubborn and rusty)
THEN jack the car up and put it on jackstands.
drain the transmission
remove the wheels, and axle nuts, and the large axle washers.
if you remove the 2 large bolts holding the strut to the knuckle, you can push the axles out of the hub IF the wheel is turned ALL the way. i find this faster than disconnecting the ball joint like people recommend.
pop the axles out of the trans with a large flat head or small prybar, remove and set the axles to the side.
take off the clutch inspection cover/clutch slave cylinder where the trans meets the engine by the oilpan. leave the clutch hydraulics hooked up, just tuck the slave cyl out of the way.
now you can see the 4 18mm bolts holding the flywheel to the flexplate. those are next.
i remove those by using a cut down 18mm socket. it will prevent the flywheel from spinning because the wrench will touch the block. -most people jam stuff in the flywheel ring gear or put a breaker bar on the balancer bolt to stop it from spinning, the socket method is definitely easier.
once those 4 bolts are out, unbolt the starter and tuck it aside leaving the wires connected, take off all the trans to engine block bolts except the top bolt, including starter bolts.
support the oilpan with a jack and a block of wood
remove the transmission mount under the battery tray
slightly lower the jack supporting the engine
take out the top transmission bolt (i had my girlfriend remove the last bolt while i was under the car holding the trans)
trans will come right out. you might have to play with the height of the jack to get the trans to clear the crossmember.
from experience....when you put the trans back in, remember that this car is goofy. the clutch assembly goes in the trans. if you bolt it to the engine with the trans out, the trans will not fit back in.
this should only take 2-3 hours to remove and it goes back together quicker than it comes out. i used loctite on the flywheel bolts
below is the alldata.com version, i wouldn't use this method as it likely has a lot of extra steps, but i'm providing it for you because it has torque specs.
2001 Chrysler Truck PT Cruiser L4-2.4L VIN B
Vehicle Transmission and Drivetrain Manual Transmission/Transaxle Service and Repair Removal and Installation
TRANSAXLE
REMOVAL
Raise hood.
Remove air cleaner assembly (Fig. 37).
Disconnect both battery cables.
Remove battery hold down clamp and bolt, and remove battery (Fig. 38).
Remove battery tray from bracket (Fig. 39).
Disconnect back-up lamp switch connector (Fig. 40).
Remove shift cable-to-bracket clips (Fig. 41).
Disconnect shift selector and crossover cable from levers (Fig. 41). Remove cables and secure out of the way.
Disconnect the vehicle speed sensor connector (Fig. 42).
Raise vehicle on hoist.
Remove transaxle oil drain plug (Fig. 43) and drain oil into a suitable container. Reinstall drain plug and torque to 28 Nm (250 inch lbs.) torque.
Using tool 6638A (Fig. 44), disconnect clutch master cylinder hydraulic tube from the hydraulic clutch slave cylinder (Fig. 45).
Remove both axle half shafts.
Disconnect power steering hose from structural collar (Fig. 46)
Remove the left engine-to-transaxle lateral bending brace and structural collar (Fig. 47). See: Engine, Cooling and Exhaust\Engine\Engine Mount
Remove bellhousing dust cover (Fig. 48).
Remove the right engine-to-transaxle lateral bending brace (Fig. 49).
Remove starter motor (Fig. 50).
Remove drive plate-to-clutch module bolts (Fig. 52).
Support engine at oil pan with screw jack and wood block.
Remove transaxle upper mount bolts (Fig. 51).
Carefully lower engine and transaxle on screw jack until proper removal clearance is obtained.
Obtain a helper to assist in holding transaxle while removing transaxle-to-engine mounting bolts (Fig. 52).
Remove transaxle from vehicle (Fig. 52).
Remove clutch module (Fig. 52) from transaxle input shaft.
If installing a new or replacement transaxle, remove the clutch slave cylinder as shown in (Fig. 53), and transfer to the replacement unit.
If installing a new or replacement transaxle, remove the upper mount as shown in (Fig. 54), transfer to the replacement unit and torque all bolts to 62 Nm (45 ft. lbs.) torque.
INSTALLATION
Install clutch module onto input shaft. Install transaxle into position.
Install transaxle-to-engine mounting bolts (Fig. 52) and tighten to 108 Nm (80 ft. lbs.) torque.
Raise engine and transaxle with screw jack until upper mount bracket aligns with upper mount. Install mount bolts and tighten to 68 Nm (50 ft. lbs.) torque (Fig. 51).
Remove screw jack.
Install drive plate-to-clutch module bolts and torque to 88 Nm (65 ft. lbs.) torque.
Install starter motor and tighten bolts to 54 Nm (40 ft. lbs.) torque. Make sure to fasten ground cable to upper starter bolt as shown in (Fig. 50).
Connect starter electrical harness and tighten positive cable nut to 10 Nm (90 inch lbs.) torque.
Install bellhousing dust cover (Fig. 48).
Install left engine-to-transaxle bending brace and structural collar (Fig. 47).
Install power steering hose to structural collar.
Install the right lateral bending brace and tighten bolts to 81 Nm (60 ft. lbs.) torque (Fig. 49).
Install both front axle driveshafts.
Fill transaxle with suitable amount of Mopar Manual Transaxle Lubricant (PN 04874465).
Connect clutch master cylinder tube to the hydraulic clutch slave cylinder (Fig. 45). An audible click should be heard. Verify connection by pushing and pulling quick connect.
Lower vehicle.
Connect vehicle speed sensor connector (Fig. 42).
Connect shift crossover and selector cables to shift lever. Install cables to bracket and install retaining clips (Fig. 41).
Connect back-up lamp switch connector (Fig. 40).
Install battery tray (Fig. 39).
Install battery and tighten hold down clamp to secure battery (Fig. 38).
Install the air cleaner assembly (Fig. 37).
Connect the battery cables.
Road test vehicle and inspect for leaks.
sanatanadharma and Fk5 like this.
Old 24 May 2014, 11:29 am
JDB JDB is offline
GREAT info guys!
And Rooster. A word of advice since I'm new and don't know anyones experience. Just in case this is your first rodeo, replace or rebuild EVERYTHING that you have to take off while you're at it.
Don't just do the clutch and pressure plate. Pilot bearing...if this car has 'um...wheel bearings, ANYthing that has to be unbolted and has similar wear time as the part you need to replace should be done while you're at it. Inspect and clean speed sensors, seals...the whole nine yards.
It's not something a shop would do, but it could save ya a LOT of aggravation later if you plan on driving the car for a long time.
Not to mention knuckle skin. ;~)
Old 24 May 2014, 12:27 pm
^ new $8 axle seals might be a good idea. it's only 5 minutes extra work. i did the rear main seal on the engine since i was in there. it's cheap and easy.
Old 24 May 2014, 09:12 pm
awesome man thanks..I"d see the you tube stuff but needed more info..done alot of chevy stuff but no front wheel drives..
I guess i"ll go with a stock style clutch set up..and throw out bearing..seen em on the bay for around $150...shipped..also seen one for $165 that red and supposed to be higher performance?...any thought s on a clutch set up for this car?..
Old 25 May 2014, 07:21 am
the stock clutch is more than adequate. i chirp third with my $150 rock auto clutch. performance clutches in a stock car are a bad idea. the increased pressure is bad for the crappy hydraulics and the increased grip is bad for the axles and transmission. unless you plan to do burnouts by dumping the clutch in third gear there's no need. the exedy that sells for $150 is self adjusting like the stock one. the performance one likely is not. i can't even begin to wonder how you'd adjust the hydraulics. if your PT is like mine, there is no bleeder on the master, slave, or the line. that might cause you an expensive headache down the road.
Old 30 May 2014, 09:58 pm
thanks for all the info...what years tran will work in a 01 model? 01-01 only? or will 3-4-5-6 fit?
Old 04 Feb 2016, 02:51 pm
_PTGT03's Avatar
im trying to get the 6638a hydraulic line disconnect tool. my entire job is now on hold. snap on will take 7 days to order it in. anybody know an alternate tool that i can use ?
Old 04 Feb 2016, 07:55 pm
Try making one by cutting the two inner prongs off a salad fork.
^that can't be hard to make
Edit: try just cutting off one middle prong and spreading them as needed.
Clutch removal Garrett Tech & Performance Forum 10 04 Mar 2014 07:31 pm
tools needed to replace 2003 clutch Anthony1 Tech & Performance Forum 1 12 Jan 2014 10:25 pm
5 speed trans oil? Kjj Tech & Performance Forum 2 29 Sep 2010 03:55 am
Headlight Removal/Replace 2k1PT General PT Cruiser Discussions 7 31 Aug 2008 05:36 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
