Apart from an engine rebuild (which I cant afford right now), has anyone had any noticeable improvement to piston slap using oil additives?
I am suspicious of a chemical that can fix a mechanical problem. |
Most of us are suspicious also. Saying that, there's a few of us that use fuel injector cleaner although some of the adds on TV say that THEIR fuel does it all. I used to believe in a can of STP to quiet down sticky valves but I don't have that problem any more.
Found this in a search: I've seen tear-downs of slapping engines and saw different things. If the piston slap is caused by carbon build up at the edges of the piston and near the top of the piston stroke then something that cleans that out can help. If it's mechanical contact between engine parts then nothing will help short of a mechanical fix. Piston slap comes from a lot of cases and until they can be separated you are just guessing, which could make solving the problem more difficult. If say GM says it causes no harm you don't know if that answer is coming from an engineer or a bean counter. But an interim solution is worth the experiment. Try cleaning out the engine and then a different oil. |
Which engine are you running? We only have the 2.4 here in the states.
Auto and oil manufacturers advise to steer clear of oil additives. They do nothing to fix piston slap and can degrade the oil.
If the issue is carbon build up, use of fuel system cleaners that have been proven to clean combustion chambers may be useful. As would air intake cleaners proven to do the same. As easy as pouring in the gas tank or spraying into air intake. Then use a better oil and fuel to maintain. Last edited by Gold2006; 26 May 2014 at 08:15 am. |
![]() Quote:
I've heard of people who fixed a leaking radiator with a chemical - I haven't had luck except I do feel injector cleaners added to gas can help.
"Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge." Isaac Asimov" '05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in '02 Silver Touring Edition w/87,000 miles |
Piston slap could also be a wrist pin too , if that's the case forget additives
![]() Full Synthetic Oil 10w30 K&N Filter Full Synthetic Trans Fluid / filter Change ![]() ![]() |
anyone remember the J C Whitney engine restore chemical treatment that had the little dark color balls you placed in each cylinder. Claimed restore engine power and reduce smoking
Guys if that's the neon 2.0, it's neither uncommon or dangerous. The video I posted is a car that has been running fine with piston slap for 60k miles. With Hondas peopl would complain they sounded like sewing machines because the rockers tick, but those are designed that way.
Thread Tools | |
Display Modes | |
GT PT-H.O engines/ecu's. | StealthMode | Classifieds: For Sale/Trade | 6 | 17 Apr 2012 03:51 pm |
differences between engines | ptguy69 | Tech & Performance Forum | 1 | 23 Dec 2010 04:11 pm |
Replacement Engines | onefastcruiser | General Turbo Discussions | 0 | 10 Nov 2010 01:29 pm |
PT Engines. NEED YOUR HELP | SilverRocket | General Turbo Discussions | 2 | 05 Jun 2009 07:12 pm |
Understanding Chemicals | turbomangt | General PT Cruiser Discussions | 0 | 21 Oct 2003 09:53 am |
