Curious, Fuel Filter Question
Like Tree3Likes
Old 26 May 2014, 09:46 am
Default Curious, Fuel Filter Question
I could probably find this info elsewhere but it's more fun here. When should the fuel filter be changed in an '04 PT Cruiser?
2004 Platinum Edition 2.4 Turbo 291,000 Miles Owner since 2008 Great car!!!
Old 26 May 2014, 10:40 am
Default Re: Curious, Fuel Filter Question
Best time is when you have to pull the fuel tank. The only time you can access it. Part of the fuel pump.
Old 26 May 2014, 10:58 am
Correct. The fuel pump and fuel filter are all-in-one and the filter should normally never have to be changed.
Old 26 May 2014, 11:24 am
boonie2's Avatar
would there be any harm in putting an "inline filter" in ? just curious
rob342 likes this.
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 26 May 2014, 11:29 am
As long as it doesn't interfere with the stock fuel system pressure which is between 53 to 63 psi.
Old 26 May 2014, 11:49 am
Thanks guys, that's good info. Sounds much like the fuel pump I changed in a Jeep Cherokee. Costly but not too bad as far as difficulty. No real reason to do it now, just need to maintain a fuel lever above 1/8 tank. .
Old 26 May 2014, 02:03 pm
Good practice to do so. The fuel pump is lubricated and cooled by the gas in the tank. Too many times running the tank down to almost empty can burn out the pump.
Old 26 May 2014, 02:21 pm
if you care enough about your car, i would recommend it really.
my quote/my opinion/my experience:
Originally Posted by rob342 View Post
the intank sock thing is more or less pretty useless for finer debris.
i changed the filter on my mustang last week and i must say, i was impressed when i emptied the old one. pour it out the filter exit and the gas came out crystal clear, poured it out the inlet and it came out like this instead:
^^ that car also has a PT-style sock on the filter. seeing this made me realize that a bunch of fine junk must still get through it.
boonie2 likes this.
Old 27 May 2014, 06:41 am
That looked like some injector-clogging crud from your 'stang filter!
Old 27 May 2014, 08:19 am
This is actually a very good idea and practiced by many that upgrade their fuel system.
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Fuel Filter Badger General PT Cruiser Discussions 3 07 May 2011 12:05 pm
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
Fuel Filter Question Darlene816 General PT Cruiser Discussions 1 03 Jun 2009 12:55 pm
