Front Driver Side Power Window Stopped Working
Old 26 May 2014, 11:12 pm
Default Front Driver Side Power Window Stopped Working
It's been quite a while since I have been here, but you guys have been so helpful in the past with my PT Cruiser so here I am again.
I have a 2006 PT Cruiser. The power window on the driver side quit working. The window is all the way down and will not budge. When I turn the switch on to make it come back up, I hear nothing. I am thinking the motor may need replacing in the door. So...I have had this problem in the past with another car (not a PT cruiser) and it was the motor that needed to be replaced to the tune of $400 a window. My son knows how to work on my car, and I am trying to see if anyone here can help me diagnose what the problem might be so we'll know what part to get. He's not a mechanic, but he has worked on my car before. The other three windows all work fine. I would greatly appreciate any help I can find as I am a single lady. Thanks!
Old 27 May 2014, 05:53 am
Default Re: Front Driver Side Power Window Stopped Working
Take the door panel off and see if the motor is getting 12v when you hit the switch - it MAY be the switch (which is a lot cheaper).
Old 27 May 2014, 08:50 am
thecabinguy's Avatar
That's exactly what happened when my right front window got stuck half way down. I was imagining $$$ when I had the car checked out and turned out to be a bad switch on the dash. Ordered the switch module and put it in myself in minutes and all works well. Here's hoping it's just the switch.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 27 May 2014, 12:57 pm
Wow you guys are great! Thanks so much, and I'll post the outcome when my son gets a chance to look at it!
Old 08 Dec 2014, 01:24 pm
this just happened to me also picking up part at the junk yard thanks
Tags
power window
Driver Side Window Problems...ANNOYING Cathy06PT PT Cruiser Convertible Forum 10 01 Apr 2018 08:42 pm
Driver's Side Front Door Doesn't Power Lock dmcondolora Sound and Security Forum 3 03 Aug 2013 09:23 pm
Driver side tail light not working after trailer harness installation sToNeCoLd_CrUzR General PT Cruiser Discussions 2 17 Jul 2012 09:44 pm
Gauges, A/C and Power Locks Stopped Working khorak Tech & Performance Forum 3 12 Jul 2010 09:43 am
headlights and power locks stopped working now car wont start nccaneskerr Tech & Performance Forum 8 14 Jun 2010 07:41 am
