Gauges..Gauges. GAUGES?
  • 1 Post By rob342
Old 27 May 2014, 02:56 pm
Unhappy Gauges..Gauges. GAUGES?
So hello the Cruisers this is my first thread on here i just recently bought a 2003 Black GT Cruiser. I love it. I have small things to adjust on it and fix here and there and of course reg maintenance. But this forum is for gauges. I have been having problems with my trigauge A pillar gauges. I have at top aem Digital Wideband O2 AFR UEGO Gauge then middle Mopar oil pressure gauge 0-100psi thrn bottom is mopar boost gauge -30 vacuum to +20 psi. The top 2 are electrical style and the boost is mechanical. So whats my problem gauges all were working perfectly fine oil press was around 45 to 60 and boost was and is still running smoothly. I top at 18lbs at WOT and hold at almost -18 vacuum not sure that is normal but its how it runs constantly. So if anyone has suggestions on that which btw the car is pretty stock as far as i can tell its got an hks blow off valve and i swap better the air box and aem 8 inch filter havent decided which i will keep yet i saw air box mods are great but still not sure without tuning the ecu. But one night i was driving and all of a sudden the AFR and Oil Press go out the afr no lights no readout nothing. Failed. The oil pressure still lights up with cluster at night but doesnt move the needle or read out anything. Im confused. I found out today they all had shared the same power and same ground no inline fuses just all tied together the ground was frame around steering column aand the power to a wire in the steering column assuming the ilumnination for cluster and ignition. Not exactly sure the color code. This is my first chrysler. So lets all work together and help me out guys that would be great! I have a ocd thing where if one thing doesnt work i feel like its all gonna fall apart. Also computer throwing p1188 code i think. The vehicle is actually seeming to run better and the turbo more under control with the code being thrown than before.
Soo sorry for long post to this but i really am stumped guys.
Old 27 May 2014, 03:05 pm
Default Re: Gauges..Gauges. GAUGES?
PM nitro he knows this stuff.
Old 27 May 2014, 03:14 pm
I know this is a huge newbie question but whats his full user name and do i do that by clicking my name in the upper right corner?
Old 27 May 2014, 03:20 pm
And where you have your pics of the 3 pts and links how do i put stuff there where do i find that signature area to edit it?
Old 27 May 2014, 03:34 pm
to pm nitro click here: http://www.ptcruiserlinks.com/forum/...=newpm&u=35802
Busted_PT likes this.
Old 27 May 2014, 08:11 pm
On top left of this page, click "User CP", then "edit signature".
Old 27 May 2014, 09:25 pm
Appreciate all you guys so far thanks for sig edit to i actually figured it out a couple hours ago
2003 GT Cruiser 123k miles
Murdered black except door handles
HKS bov
Stock internals not quite sure thou just bought it
Trigauge a pillar afr,oil press,boost.
Hurst short throw
Fully loaded rides pretty well love it :-)
Tags
air, boost, fuel, gauge, oil
Gauges went out? Need help please! tnc112105 General PT Cruiser Discussions 10 22 Jul 2011 09:38 am
ac gauges? cowboyinboxers Tech & Performance Forum 1 07 Jul 2011 01:16 pm
Can you say Gauges! Wicked_PT General PT Cruiser Discussions 24 23 May 2009 06:15 pm
What three gauges? 340X2C Tech & Performance Forum 2 06 Nov 2008 07:43 pm
Add-on Gauges Help 2K1Cruizer Tech & Performance Forum 2 03 Dec 2001 07:42 pm
