No horn lock confirmation?
Old 27 May 2014, 11:35 pm
Default No horn lock confirmation?
Is this normal or something must be disconnected? No horn beep when pressing lock or when I press panic alarm only my lights flash but no horn O.o I can however hear a clicking noise inside the car
2003 pt cruiser N/A
Old 27 May 2014, 11:40 pm
randyincctx's Avatar
Cool Re: No horn lock confirmation?
Sounds like you may need to replace the horn relay......You can check it by swaping another relay and try honking the horn by hand or with the remote
Aka:~KILLER~
Old 27 May 2014, 11:46 pm
Default Re: No horn lock confirmation?
my horn works but not when using remote
my remote only has lock,unlock,panic but when I press panic or lock I can't hear the horn chirp
Old 27 May 2014, 11:56 pm
Question Re: No horn lock confirmation?
This is an all factory alarm/anti-theft system correct?......Not aftermarket?
Aka:~KILLER~
Old 28 May 2014, 12:00 am
I think so the remote says daimler chrysler in the back which makes me believe its stock
Old 28 May 2014, 12:05 am
Post Re: No horn lock confirmation?
If yours is a factory system,it sounds like you may have inadvertantly disabled the horn feature,which sounds every time you lock & arm(or unlock & disarm) a vehicle equipped with the sentry system.
The horn chirp that signals that the doors have been locked/unlocked can be activated or deactivated by using the following procedure:
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter for between four and ten seconds.
3. Continue to hold the Unlock button and press the Lock button.
4. Release both buttons. A chime will sound to signify that the process is complete.
Try that and see if that corrects your issue.........
Aka:~KILLER~
Old 28 May 2014, 12:16 am
It did nothing I did hear the chime but the horn still does not work
Old 28 May 2014, 12:41 am
Did you just try the sequence once?.....I mean it was kind of a slim chance that you would have accidentally entered the 'stealth mode',but it definately was worth the shot.
Aka:~KILLER~
Old 28 May 2014, 12:42 am
I did it 3 times and still no luck
Old 28 May 2014, 12:57 am
Another long shot....But you can try disconnecting the battery for about 10 mins,step on the brake to dissipate any residual charge,then re-connect the battery,and see if that clears the issue.
If that doesn't work it could be an issue with the RKE,which sends the signal thru the sentry alarm,to honk the horn when using the key fob remote.
The RKE on the PT Cruiser is located in the top center of the dash,and is subjected to the same temperature extremes as the dashboard,especially the heat of Summertime,year after year.........RKE failure is somewhat common,especially the older the RKE gets,and depending on the amount of heat.
Heat & electronics don't go together very well,and just think about how hot a dash can get sometimes.
Aka:~KILLER~
How can I disable the horn/toot when i push "lock" kurty General PT Cruiser Discussions 25 15 Aug 2016 08:54 pm
2006 Jack point Confirmation - front rvsailormm1 Wheels, Tires, Suspension 12 13 Dec 2013 02:14 am
05 Horn Goes Off By Itself bethelkid General PT Cruiser Discussions 2 30 Dec 2010 11:11 am
Horn coponova Tech & Performance Forum 8 01 Apr 2009 11:03 am
A-uo-Ga Horn turbomangt General PT Cruiser Discussions 14 06 Feb 2003 10:01 am
