pulsating, uneven braking
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By Busted_PT
Old 29 May 2014, 07:51 am
Question pulsating, uneven braking
When braking the car pulsates like a warped disk. But after checking them, they're not warped. The brake pedal doesn't pulsate either. The car doesn't brake smoothly it jerks to a stop. Any ideas guys?
Old 29 May 2014, 08:00 am
Default Re: pulsating, uneven braking
What is the condition of the pads? How did you check the disks for "trueness" (no warping)?
Old 29 May 2014, 08:07 am
How did you measure for correctness of the disc?
What are the conditions of the calipers?
When did you last do a brake fluid flush?
Old 29 May 2014, 08:10 am
I replaced the discs with new ones and the pulsating came back.
Original calipers, 125,000 miles.
Had the fluid flushed maybe 5-6 yrs ago.
Old 29 May 2014, 08:13 am
The problem may be stiction in the *calipers. They are inexpensive and easy to change.
The *brake fluid is long over due for a good complete system flush.
rckstein likes this.
Old 29 May 2014, 08:29 am
Replaced pads or the rotors? Also have you checked the rears? If they are bad or not adjusted if drums. You can warp the new ones if the rears are not helping in the stop process.
Old 29 May 2014, 09:42 am
Good point.
Old 30 May 2014, 12:20 am
randyincctx's Avatar
Lightbulb Re: pulsating, uneven braking
Another possibility.....Whenever the wheels were last removed,they weren't torqued in the correct sequence('star pattern') and/or not torqued to specs(100 ft/lbs).
Aka:~KILLER~
Old 30 May 2014, 12:35 am
You need a dial indicator to visually check for warped rotors. If your in the rust belt and you remove your rotors and don't reinstall them exactly as they were removed there may be enough rust or dirt between the hub and the rotor to make it wobble, it doesn't take much. Damaged wheels or tires may do the same.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Uneven Brake wear. cocacola144 Wheels, Tires, Suspension 5 15 May 2012 11:08 pm
pulsating thingy JVZL1 Tech & Performance Forum 10 12 Dec 2011 06:16 pm
03 turbo gt cruiser has uneven idle when stopped gwynrhyn General PT Cruiser Discussions 12 19 Aug 2011 11:12 am
Uneven touch up PTRobert The Detail Shop 6 28 Sep 2005 08:19 am
uneven acceleration mo-cash General PT Cruiser Discussions 4 22 Jan 2004 11:53 pm
