AC delete
Old 30 May 2014, 11:30 am
Default AC delete
i see they list a non-ac belt. since i'm setting my car up as a winter car, i may delete the compressor and all associated hardware. i really like the idea of having more room to work, less rotating parts, and less weight.
is it safe to ASSume that a PT without air would have the belt routed like this?
Old 30 May 2014, 11:49 am
Default Re: AC delete
Seems logical that it would run that way. You'd just have to figure out what length belt to use but I'm not sure if the tensioner pulley would put enough tension on the new belt.
Old 30 May 2014, 11:55 am
LionPT's Avatar
I wonder if there would be tension if he run the belt inside the tensioner pulley...he might have rig a new pulley.
Old 30 May 2014, 11:59 am
they list a non-AC belt at the parts store. i guess buy one and i'll just see if it fits. i'm just wondering/guessing if the tensioner is the same.
only problem is the tensioner would have to spring in the opposite direction to do that.
Old 30 May 2014, 12:04 pm
LionPT's Avatar
Sorry, what I meant was...depending on where the tensioner pulley rested...fully to the right...you might have some room to wrap around the inside...but, of course there would be no tension anymore.
Using a bigger pulley would probably be a better fix.
Old 30 May 2014, 01:00 pm
The ac plays a big role in the defrost setting. So if it works, be better to leave it as is. If not then maybe ok.
Old 30 May 2014, 01:11 pm
The correct belt mounting would be with an idler pulley added.
Too much to type calling you now.
Old 30 May 2014, 06:04 pm
I do know that in later years they offered PTs with no A/C. Maybe a later Haynes manual would show?
For the first several years all PTs had A/C.
Old 30 May 2014, 06:08 pm
I think you are correct.
I remember a member posted that his country the PTs did not come with factory AC?
Old 30 May 2014, 06:19 pm
i found a weird setup on a 2007 using alldata.
i could look it up on there if anyone can figure out a year or vin had that was an option
2005 PT With Muffler Delete TeamTFR PT Cruiser Videos 0 16 Feb 2013 11:38 pm
Muffler delete sleepy General Turbo Discussions 14 15 Dec 2012 06:27 pm
DELETE!!!!!!!! WolfmanG Feedback and Support 4 04 Apr 2012 07:20 pm
Can I delete a post Retroguy Feedback and Support 5 27 Feb 2011 07:05 pm
Account Delete athelite Feedback and Support 3 15 Nov 2010 07:22 am
