Power Steering Leak Part II - Help Identify Hose Please
Old 31 May 2014, 11:04 pm
Exclamation UPDATED: Power Steering Leak Part II - Help Identify Hose Please
UPDATE: The area where it is leaking is actually right where the BOTTOM hose (that is metal at the ends) is connected to the BOTTOM of the P/S pump. It is NOT at the top of the pump as I originally thought.
I have a leaking power steering fluid and I just need help identifying the EXACT name of where it is leaking so I can buy a replacement part.
The leak is coming from THE BOTTOM OF the P/S pump. I am pretty sure it is right where the metal hose part connects to the BOTTOM of the P/S pump.
Assuming I have identified the correct place where it is leaking, which hose is it exactly?
And if you really want to help a brother out, would you know of an inexpensive third-party part (and have the part number)?
I went to O'Rilly and just inquired about power steering pressure hoses in general and they said that it is a special order part, but they didn't really seem so sure they were looking up the right part.
Thanks in advance.
Old 01 Jun 2014, 07:11 am
Default Re: Power Steering Leak Part II - Help Identify Hose Please
Found this in a search. There was no part numbers attached to the picture. It's the Power Steering Pump Pressure Hose that runs from the pump to the steerng rack.
Old 01 Jun 2014, 07:26 am
There are actually 2 hoses that come from the Power Steering Pump. On my 2001 the Power Steering Pressure Hose (2) is part Number 4656 421AD. The Power Steering Hose (3) is part number 5272 867AA.
As I said: These part numbers are for my 2001, Left Hand Drive 2.4L 4 Cyl. DOHC
Old 01 Jun 2014, 09:56 am
Thanks for the diagram and the explanation.
The power steering pump is ABOVE the A/C compressor??? Did not realize that.
OK, assuming that it is JUST that hose that is leaking, how hard is it to replace it???
Google has not been my friend. I seem to have a hrad time finding any sort of insturctions that accurately deal with how to replace JUST that hose.
I have seen tutorials for removing the whole P/S pump and they seem very complex (involve moving / removing the A/C and the radiator).
Is it going to be as hard just to remove and replace that hose?
Should I remove the fender?!?!?!
Old 01 Jun 2014, 10:39 am
Sorry, can't answer your questions. When My Power Steering Pump went bad it was still under warranty so I didn't have to do anything.
Old 01 Jun 2014, 10:46 am
Ok, thanks though. You have already been a big help.
Old 01 Jun 2014, 11:40 am
Default UPDATE: This is the hose
UPDATE: The hose that is leaking appeears to be the one marked as item #2 in the diagram that crewzin supplied:
It appears to be leaking exactly where the metal nipple part screws / bolts into the bottom of the P/S pump.
1) How hard is this to change? It looks like it will be a PITA
2) My car has 90K miles on it. I was going to take it to the shop and have them replace the timing belt / water pump (they quoted me $800, which seems pretty cheap). Should I just have them do the hose at the same time?
They said that there was no additional labor charge to remove THE PUMP, but they said it would be $250 labor to replace THE HOSE?!?!?! Does that seem right?
Thanks in advance.
Old 01 Jun 2014, 01:43 pm
Default Re: UPDATE: This is the hose
Thanks in advance.
No That is way to much labor for that if they are in there doing the belt.
Old 01 Jun 2014, 02:58 pm
that's what I thought.
They said that replacing the P/S pump wouldn't require additional labor because they would already be "working in the same area" when changing the timing belt, but that hose was "in a different area."
Old 01 Jun 2014, 03:54 pm
Take that diagram to them and have them explain where all that labor is with that other end of that hose.
Power steering hose leak, help! PTworker Tech & Performance Forum 23 22 Mar 2015 06:38 pm
Power Steering Return Hose? parkinsonrich Tech & Performance Forum 4 13 May 2013 07:25 pm
Power Steering Hose Won't Stay On Terrib11 General Turbo Discussions 0 21 Jan 2013 04:40 pm
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
Power Steering Hose Needed 340x Classifieds: For Sale/Trade 1 29 Jun 2009 04:53 pm
