OBD-II Port diagram
Like Tree4Likes
Old 01 Jun 2014, 10:01 am
Default OBD-II Port diagram
Hello All,
Thanks in advance for the help. In addition to using everyone's experience on an overheating problem (still underway), I have a different issue that needs addressing. I am in need of the wiring diagram for the OBD-II port. I kicked loose the plastic plug that separates and positions the leads and want to put the plug back together.
Ron
2001 PT Cruiser 100k miles.
Old 01 Jun 2014, 10:32 am
Default Re: OBD-II Port diagram
Data Link Connector Pin Out
Data lost due to national rejection of fact and expertise
rob342 likes this.
Old 01 Jun 2014, 10:35 am
chuzz likes this.
Old 01 Jun 2014, 10:36 am
how come his says white and mine says black?
i got mine from AlldataPro for a 2001 pt
let us know which is right. i'm curious.
Old 01 Jun 2014, 11:24 am
One piece is black and the same shape as shown in Rob's diagram. This piece goes on the outbound side of the mounting bracket. The other piece is white and more rectangular
I have 7 leads and no white wire (#15) so I would say the "black" diagram is what I have. I will also confirm wire colors to be sure.
Thank you for the help.
Ron
Old 01 Jun 2014, 03:37 pm
My post (white connector) was from 2004 shop manual.
Here is information from the 2002 Mitchell Repair Information guide.
Old 02 Jan 2017, 04:19 pm
This is helpful but which color wire goes in which location?
Old 02 Jan 2017, 04:57 pm
Read the diagram that Rob posted. If you don't know the codes for the colors, just ask. For example, the wire that goes in cavity 2 is violet and yellow. The data link is numbered from the left side to the right. Cavity 1 is the top left and each cavity # goes up to #8. Then bottom left starts with cavity #9. Any questions, please post back. The only dumb question will be the one you DON'T ask. We're all here to help, if and when we can. Thanks for posting the diagram, Rob! You da man!!!
Old 02 Jan 2017, 06:51 pm
Thanks for the info Chuzz. Exactly the explanation I needed. I appreciate it very much.
rckstein likes this.
Old 02 Jan 2017, 07:10 pm
rckstein's Avatar
Welcome to the forum
You should go to the New Members section and introduce yourself
ecu-pcm diagram adam_p1 Tech & Performance Forum 2 15 Jan 2013 09:27 am
fuse box diagram joyjoy Midwest PT Forum 6 09 Jun 2012 04:04 pm
Diagram on how to take a Turbo in and out? Petey2506 Tech & Performance Forum 4 26 Mar 2011 10:20 pm
A/C diagram windsblow General Turbo Discussions 3 19 Jun 2010 03:30 pm
Need Diagram KingKole02 Tech & Performance Forum 5 24 Jan 2006 09:09 am
