Whistling steering pump?
Like Tree3Likes
  • 1 Post By NitroPT
  • 2 Post By rockandroller
Old 02 Jun 2014, 02:02 am
rockandroller's Avatar
Question Whistling steering pump?
The other day I had the power steering pump return hose replaced (the low-pressure hose) , and can notice now a very high-pitched 'whistling' sound (QUITE LOUD) which changes pitch as I move the steering wheel.
It seems most noticeable when the engine is cold, but I've also heard it after warm up.
I'm thinking it could be some kind of belt squeal??
Does anyone know if they have to loosen the belt to change the lower power steering hose? I'm thinking maybe the belt wasn't tensioned right, or got some oil on it, or maybe its just not riding right. (or the idler bearings are going?)
Probably time for new serpentine belts anyway - but it just seems like a big coincidence that the power steering hose was just replaced...
2004 'Turbo Lite'
Old 02 Jun 2014, 05:48 am
Default Re: Whistling steering pump?
The pump is known more for a "groan". Whistle sounds more like a belt.
Old 04 Jun 2014, 09:39 am
check the steering fluid level?? mine looses a bit now an then and starts to whine when you turn the wheel...I just top it off and it gos away..I use the kind thats says it stops leeks too..and u could have air in the line?? topping it off will prolly help
Old 04 Jun 2014, 09:48 am
Depending on mileage this is may be your warning sign to change and flush the power steering fluid. There is a little known check valve in the rack that becomes slowly becomes plugged which can cause the pump along with the rack to fail if the power steering system is not serviced.
Old 04 Jun 2014, 07:32 pm
QUESTION:
How likely is it that high pitched whistling sound is the serpentine belt pulley and NOT his power steering pump?
(I ask because I just had the shop replace my power steering hose AND the power steering pump and I STILL have that high squeaking sound, and the shop says it is the serpentine belt pulley.)
Old 04 Jun 2014, 07:52 pm
Give the pulley a shot of silicone spray directly on it's center, if squeal/whistle changes, then it is the pulley.
Old 05 Jun 2014, 12:33 am
Thanks for all the hints... I dropped by the shop yesterday morning, and of course THEN it was making hardly any noise. My mechanic topped up the fluid a bit, and it is quieter, but I can still hear it a little from time to time. I'm wondering if maybe that (very slight) sound was always there and I just never noticed?
Anyway I'm going to try the idler lube trick, and investigate that steering rack check valve. (Will ask if the fluid was flushed when the hose was changed, but I imagine not - my mechanic leans rather strongly towards the "if it ain't broke, don't fix it" school)
2004 'Turbo Lite'
Old 05 Jun 2014, 12:45 am
Hmm another good hint to find another "mechanic".
The check valve is none- serviceable , all you can do is flush and refill the Hydraulic power steering system with new fluid.
FYI generally speaking lubricants like WD-40 or Silicone spray etc are extremely flammable. It really is not the best idea to spray a running engine with them. In the case of locating the sources of squeaks, rattles and rolls , the safer method is a spray bottle of water.
zonoz likes this.
Old 05 Jun 2014, 01:03 am
I was planning on spraying on a little "RELEASEALL" - it is claimed to be
Non-Toxic
Biodegradable
Non-Chlorinated
Non-Flammable
Non-Toxic
( that written in big bold lettering all over the can... )
Tho - looking at the MSDS, it appears to actually be "moderately" flammable and "slightly" toxic
quicksilverdon and zonoz like this.
2004 'Turbo Lite'
Old 24 Jun 2014, 12:20 am
Ahah - Just found something interesting, apparently there was a factory TSB:
19-001-04 MAR 04 P/S - Whistling Sound When Steering Wheel is Turned
Does anyone know where I can download a copy? Seems it's got something to do with a special hose replacement - and seeing as I just got the hose replaced...
2004 'Turbo Lite'
Power Steering Pump?? TurboDucky Tech & Performance Forum 2 28 Mar 2012 08:15 pm
Power Steering Pump Out! lovemyturbo Tech & Performance Forum 4 12 Feb 2011 06:10 am
Power Steering Pump Chrysler1924 Tech & Performance Forum 7 06 Aug 2010 02:51 pm
01 Power Steering Pump hoje00 General PT Cruiser Discussions 1 15 Apr 2010 06:41 pm
Steering is whistling...?! whitbyPT Wheels, Tires, Suspension 2 27 Jul 2008 01:42 pm
