Timing Belt
Old 02 Jun 2014, 05:20 pm
MrGeo's Avatar
Default Timing Belt
My 02 is coming up on 100,000 miles and was looking at the forum to check on timing belts and decided to pull the top bolt off the belt cover an see what I could see. It is black and fairly shiny, showing little wear. question is what color and consistency does an orig have? And what valve is it that has a tendency to break if it is not loosened when a new belt is installed, and where is it located? Wondering if I need to think about this. THX GEO.
MrGeo
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=39820&dateline=136534  3203
Old 02 Jun 2014, 06:04 pm
Default Re: Timing Belt
Old 02 Jun 2014, 06:05 pm
mine still had yellow lettering on it and looked pretty good, well, other than the place it snapped.
there is no valve to break. the tensioner controls the belt tension and that gets replaced at the same time, it should be included in the kit.
hope this helps
-mine snapped when i hit the brake without enough time to push in the clutch. wheels locked up, motor stopped, valves tried to keep going.
Old 02 Jun 2014, 07:26 pm
MrGeo's Avatar
Thanks for the comment, interesting.
MrGeo
Old 03 Jun 2014, 09:50 am
Rob:
How many miles did you have on your car when the timing belt broke?
I know at 90K I am pushing it, but got to see about getting some dollars first. I might have to go another 2K or 3K miles first.
Old 03 Jun 2014, 10:05 am
If the pt has been setting for long periods in it's life. I would be worried more. But if it was driven often and just not many miles, I would feel safer because of the dry rot issue. Rubber doesn't like to sit around. JMHO.
Old 03 Jun 2014, 10:12 am
Originally Posted by myjeephatesme View Post
Rob:
i was at 214,900. second replacement/third belt for mine
Old 03 Jun 2014, 10:20 am
MrGeo's Avatar
Florida car I got it a year ago w 79000 miles, has 99000 now. I looked at some Jpegs on the internet and it looks like the new ones. if it is orig it still looks good i'm thinkin. THX. I drive it most the time, auto trans don't get on it hard much.
MrGeo
Old 03 Jun 2014, 10:45 am
The belt on my son's 03 GT failed at about 93K about 2 months ago. No damage to anything else but his wallet. He didn't have his Timing Belt Fund started yet, he does now.
Timing belt Chrisd069 General PT Cruiser Discussions 1 21 Nov 2013 02:27 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
