| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I'm curious as to which brand of wires to buy when I change to Champion Double Platinum #7440. I've got a non-turbo 03, 5 speed
and do 80% of my driving on the freeway(500-600 miles/week). I'm thinking of 8mm Magnecor Blue Wire. Will that be OK?? Any help would be appreciated. Also, can you get wires and plugs at a Kragens, AutoZone, etc? |
I like Magnecore's. Can buy them at Revel, http://www.revelenterprises.com/pt_cruiser_magnecor.htm . And they carry the KV85 and R100 wires too at a reasonable price. If you can afford it, buy the KV85 or R100 wires. Otherwise the blue Magnecore 8mm Electrosports 80 are a fine replacement set.
Truck Performance carries JBA wires, http://www.truckperformance.com/prod...oductID=703100 , the cylinder #'s are marked on each wire. Taylor wires is another good choice. They make branded wires for Crane and many other well known performance companies. Spark plugs can be bought locally fairly easily. Spark Plug wires that you want may be problematic, depending if your parts or speed shop can special order the wires for you and at the price you are willing to pay.
2002 Almond Pearl Limited Edition 27K It\'s nice to be important, but it\'s more important to be nice. http://sci-fi.ptenthusiasts.net/
What are benefits of getting the larger mm wires?
KingKole02 ![]() SW Florida PT Cruisers Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics For cruiser pics go to: http://ptcw.truckmoxie.com/mygallery.ten?id=3464 http://smg.photobucket.com/albums/v8...0in%20my%20PT/ For my personal page, visit http://www.kingkole02.com http://random-input.blogspot.com http://www.ptcruiserweekly.com www.jumpsometravel.com Travel Everywhere! - Owner |
The stock wires gave me a miss somewhere around 30,000 miles. I got Crane wires (which I guess are Taylor) from RaceAndStreet. Now have 72,000 miles, haven't skipped a beat.[?]
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Hope this helps.
Sci-Fi,
Thanks bro, this does help some. So basicly your info breaks it down to two wires. Magnecor 8mm Electrosports 80 Ignition Cables & Magnecor KV85 Competition 8.5mm So now which one is the best. I would say the blue one for my everyday driver. Im I right?
The choice is up to you. Compare some of the specs:
Magnecor 8mm Electrosports 80 Ignition Cables OVERALL LEAD ASSEMBLY Outside Diameter of Cable............8mm. Colour...........................................B lue. Boot/Terminal Configuration.........Various - to suit different applications worldwide, as well as customer special requirements. Country of Manufacture.................Cable: USA. Assemblies: USA, UK and Australia. CABLE Construction Type..........................Silicone rubber insulator, re-enforcing braiding, high-tear strength silicone rubber outer jacket. Insulator Material...........................High dielectric silicone rubber. Outer Jacket Material....................Extreme high-tear strength silicone rubber. Heat Resistance.............................260o C (500o F) service temperature. Dielectric Strength....................... .55,000 volts. CONDUCTOR Conductor Size........................................1.75 mm in diameter. Conductor Type..........................................Magn ecor Metallic Inductance CN20 RFI and EMI Suppressed. Core.............................................. Ferrimagnetic base over Kevlar. Windings.......................................48 turns per cm (120 turns per inch). Windings Material.........................Chrome-nickel. Resistance.....................................98 ohm per cm, 3K ohm per ft. + 10%. Capacity.........................................5 5,000 volts, 2kVA. TERMINALS Spark Plug.....................................Stainless steel snap-lock 180o bendable and fixed 90o styles. Distributor and Coil........................Brass, stainless steel and beryllium snap-lock 180o and 90o styles. PROTECTIVE BOOTS Spark Plug.....................................Silicone 205o C (400o F) - selection of straight, 45o and 90o styles used where applicable - special connector assemblies for some applications. Distributor and Coil........................EPDM or Silicone - some sets will be fitted with OE style connectors. Magnecor KV85 Competition 8.5mm ![]() The KV85 conductor size (for lack of a better term, the internal wire size) is about 45% thicker in diameter than the 80 series (2.5mm vs 1.75mm). Resistence is reduced about 25% (2.2kOHM ft vs 3kOHM ft. There are other differences you can compare for yourself. Ultimately, you have to decide whether or not the price difference (about $10.00) is worth it.
I ordered the 8.5 red wires.
Thanks for all your help Sci-fi.
King Good choice IMHO I like the Magnecors....
I think it's hard to do worse than the stock ones. [xx(]
| Spark Plug Wires | thegoldpt | Tech & Performance Forum | 22 | 24 Dec 2007 11:08 am |
| Best Spark Plug Wires for 03 Turbo? | zzzhuh | General Turbo Discussions | 10 | 13 Oct 2005 04:49 pm |
| spark plug wires | dzinman | Tech & Performance Forum | 1 | 28 Jul 2005 01:25 pm |
| no-name spark plug wires | Probedude | Tech & Performance Forum | 9 | 11 Jun 2005 12:13 am |
| Replacing Spark Plug Wires | LT Almond GT | Turbo Performance | 4 | 08 Jan 2004 10:49 am |
