Cruiser swivels to the sides and vibrates
  • 1 Post By RacerX125
Old 04 Jun 2014, 01:39 pm
Question Cruiser swivels to the sides and vibrates
Well my 2003 na cruiser kinda wiggles on the rront like if the wheels are loose and me steering wheels wiggles left to right a little when driving and when reaching highway speeds it vibrates it doesnt vibrate hard but just enough to vibrate the ntire car and it seems to be coming from the front right side.
Has 104k miles. Tire preasure was set to 40 psi on all four tires. Could bad wheel bearings cause this? Or something else?
Old 04 Jun 2014, 01:56 pm
Default Re: Cruiser swivels to the sides and vibrates
my car would have a weird steering wheel wobble with a repetitive rythmic slight knocking sound. if that's what you are describing it ended up being a tierod end on my car. i could yank up and down on the tie rod and it moved 1/8".
the wheel bearing sound gets louder as speed increases and gets louder/quieter when you swerve left/right
the tie rod wobble i had was more random. i didn't always notice it, sometimes roads made it seem worse than others. if i remember right it was more noticeable while coasting
jack up the car and yank up and down on the tie rod end. it's free (:
next id rotate the front tires to the back to see if the sound moves.
Old 04 Jun 2014, 01:59 pm
I have this funny creek sound when going over bumps and sometimes when turning i hear creeks like a quick brrik sound
Old 04 Jun 2014, 02:01 pm
creaking is usually a bad ball joint
jack up the right front and yank the bottom of the wheel in and out. it should not wiggle.
Old 04 Jun 2014, 02:07 pm
I've been riding it making it that sound for a while now without any damage can maybe diving without changing it had completely damaged it and maybe thats why its vibrating? Or th ball joint cant be cause?
Old 04 Jun 2014, 02:14 pm
You can keep going till one or the other gives out. But if you do you won't be driving it home. If you do get Ito a wreck when it lets go. Or do as rob said and check it out to see what you need under there.
Old 04 Jun 2014, 02:20 pm
Hell no! My cruiser is my life, if my cruiser dies I will follow. If it stops working I start fixing. I will never let my car go as long as I live. So I will go tonight to check everything out and at the same time make a hole in my pocket
rob342 likes this.
Old 04 Jun 2014, 03:47 pm
If your handy maybe you will keep some bottom in that pocket. You will be a lot safer when your done. Keep us up on your progress.
Old 04 Jun 2014, 07:37 pm
If no wheel movement, get an alignment.
01-05 PT headlamp assembly (both sides) dom92 PT Pass It On 13 28 Apr 2014 11:17 pm
2009 pt cruiser vibrates at idle... ive read all the posts. im stumped. help! jstnmlls Tech & Performance Forum 10 03 Dec 2012 11:56 pm
OEM Ground Effects, Sides only Busa_Powered Exterior Accessories Forum 6 11 Sep 2012 09:51 pm
xenon sides?? DBROWN03 Exterior Accessories Forum 5 11 Jan 2004 06:01 am
GT Badge on the sides turbomangt Exterior Accessories Forum 3 14 Jan 2003 01:12 pm
