2002 2.4 litter won't start
Old 05 Jun 2014, 08:51 am
Default 2002 2.4 litter won't start
All of a sudden it just died and wouldn't start. We put new a head gasket, timing belt, crankshaft positioning sensor and camshaft positioning sensor. It has spark and fuel pressure. And absolutely nothing happens with starting fluid. Any ideas?
2002 2.4 lt PT Cruiser won't start - YouTube
here is a YouTube video of what it is doing. it just cranks over but doesn't try to start.
any help/ideas would be greatly appreciated!
Old 05 Jun 2014, 09:53 am
Default Re: 2002 2.4 litter won't start
This incident will have about 3-7 DTCs (engine code). It would be helpful to review them. Sure spins easy? I can tell you are accustomed to starting cars that have carburetors. LOL The PT is EFI you do not need to throttle during start.
I see this is your first post generally it is more polite to do an introduction before jumping in with a problem? We are all just people like yourself. We are here to help but like to think a new member might stick around instead of just using us for help and information right off.
WELCOME TO THE FORUM
Old 05 Jun 2014, 10:22 am
LionPT's Avatar
What about the Starter..??
Old 05 Jun 2014, 10:28 am
harrym's Avatar
minino614-Please post info about yourself in the "new members" section! Welcome to the forum!
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Old 05 Jun 2014, 11:20 am
I know your not supposed to pump the gas, but it sounds like it more closer to firing. As far as the personals, i live in Omaha Ne, my whole life. I also always return a favor if I can.
Old 05 Jun 2014, 11:56 am
I suggest to get a scanner and see what engine code have come up. A no start like the one in your video will always have them unless the PCM failed.
You may attempt the key dance that some member like to use but I think it may not work as well or display all the DTCs considering how many codes will be active fault under your no start problem.
Old 06 Jun 2014, 01:01 am
randyincctx's Avatar
Question Re: 2002 2.4 litter won't start
It also helps to give some insight into somethings,if we are graced with knowing mileage,recent work performed,etc.....The more we know the better equipped we are to offer help.....j/s
Aka:~KILLER~
Old 06 Jun 2014, 11:51 am
boonie2's Avatar
It sure sounds like its turning over easy , strange sound
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 06 Jun 2014, 12:24 pm
to me it sounds like it's turning over way too fast, which indicates a timing belt failure. remove the camshaft sensor and see if it's moving underneath it.
2016 Kia Soul Plus Black
Old 06 Jun 2014, 07:48 pm
They replaced the timing belt.
I suspect the belt is on wrong - cams - timing marks - weren't lined up properly.
2002 PT Sometimes won't start bighowie General PT Cruiser Discussions 2 28 Oct 2013 11:19 am
My 2002 Cruiser won't start Racechaser Tech & Performance Forum 11 12 Aug 2012 12:42 am
2002 PT died & will not start KimT General PT Cruiser Discussions 20 16 Mar 2012 10:05 pm
2002 PT CRUISER WON'T START -98k MsLeah General PT Cruiser Discussions 9 12 Jun 2010 08:19 pm
2002 PT Cruiser will not start!!! WTF!!! thinkinboutit General PT Cruiser Discussions 3 16 Feb 2010 10:53 pm
