Automatic Transmission Fluid Change
  • 1 Post By NitroPT
Old 05 Jun 2014, 02:18 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Automatic Transmission Fluid Change
The book says every 30,000 miles.
But what if you only drive 3,300 miles per year? Run it at highway speeds once in a while.
My ATF looks and smells perfect. Transmission runs perfect.
My PT: 2001, 98,300 miles. Runs perfect.
Old 05 Jun 2014, 02:30 pm
Default Re: Automatic Transmission Fluid Change
It's to late when you notice something. There is a filter in there. Over time becomes more clogged until fluid starvation takes its toll. No more perfect.
Old 05 Jun 2014, 03:47 pm
The 30,000 is for a pan drop and filter change and fluid fill a minor service that shops only charge 49-89 to perform? You can do it yourself easy enough with common garage tools for around 30 bucks?
It is called preventive maintenance. IMHO a complete flush is what you should really be doing at this point.
Do a search of this forum and you will read several postings of troubles with the ATX which IMO can be traced to infrequent filter and oil changes and not doing factory updates on the TCM. Sure you might be the lucky one and be able to go one more mile and make your no trouble claim and then what when you come to a stop and thats it no movement!
VNT likes this.
Old 05 Jun 2014, 07:16 pm
Think how many shifts are in those short trips...
Miles on a clear highway exercises the trans less than short hops.
Find a place with a flushing machine, and have the trans flushed. Be sure they only use ATF + 4.
Old 09 Jun 2014, 11:47 am
My owner's manual says every 60,000 miles.
2008 PT Cruiser Touring 135,000 miles
Old 09 Jun 2014, 12:15 pm
My Chilton Manual says 30,000 miles or 2 yrs.
I just found my 2001 PT Owner's Manual from Chrysler and it says 48,000 miles.
I changed my A/T fluid and filter 7,000 miles ago but, it has been two years!
Also check this out from Havoline ATF+4, specifically for Chryslers100,000 miles!!
Automatic Transmission Fluid, ATF4, Dexron VI, MD3 - Havoline
I am wondering wether fluid formulation has improved so much in the las 13 yrs, which is the age of my PT, to the point were its life has been extended.
Old 09 Jun 2014, 01:29 pm
Not sure why this is such a thought exercise question? If you value peace of mind and your PT just change the fluid. It is a good preventive and inexpensive maintenance even if the fluid in your Transmission is currently just ok?
If you feel that you fit into the average driving and operating environment category the recommendation by OE and oil supplying companies advertise than follower there information?
Personally I like the Peace of mind!
Old 09 Jun 2014, 04:52 pm
boonie2's Avatar
When in Doubt , Change it OUT"
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 09 Jun 2014, 05:05 pm
cruserdad1976's Avatar
5 quarts of ATF 4 a filter is about $75 not a lot for peace of mine
Transmission filter change + fluid kctobyjoe Tech & Performance Forum 6 13 Dec 2013 10:54 pm
Transmission Fluid and Filter Change Questions Patrick_Dickey Tech & Performance Forum 32 10 Nov 2013 11:46 am
Automatic transmission oil change bhunt41 Tech & Performance Forum 2 02 Dec 2011 11:10 am
Did Transmission Fluid Change...Now Its Stuck On 1st Gear sirminder Tech & Performance Forum 25 28 Jun 2011 02:42 pm
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
