Gauges Help
Like Tree2Likes
  • 2 Post By Busa_Powered
Old 05 Jun 2014, 05:03 pm
Default Gauges Help
Anyone have a walk through on how to wire up gauges on an 06 PT Cruiser NON Turbo
Old 05 Jun 2014, 05:08 pm
Default Re: Gauges Help
Can you be a bit more vague?
rob342 and podo2000 like this.
Old 05 Jun 2014, 05:45 pm
usually...
red goes to a power wire that comes on with the key
black is ground
white is to the dimmer switch.
green goes to sender.
Old 06 Jun 2014, 07:10 am
Im wanting to install a oil pressure water temp and oil temp gauges. I want a piller for it, but cant find any for the 06 pt. Any help on where to tie into or if adapters are needed will be great.
Old 06 Jun 2014, 10:45 am
guage pillar pod:
http://www.summitracing.com/parts/atm-17215
the oil temp you'd need to tap the oil pan and install a temp probe.
the water temp you'd want to add a sensor to the lower thermostat housing
the oil pressure you would likely need to install a T fitting into the back of the block so you could leave the factory pressure sensor attached and add an additional sender for the aftermarket gauge.
Old 06 Jun 2014, 11:11 am
cruserdad1976's Avatar
everything rob says is the gospel but if you feel you need more info find a post from nitro and check out his guage assorment
Gauges went out? Need help please! tnc112105 General PT Cruiser Discussions 10 22 Jul 2011 09:38 am
ac gauges? cowboyinboxers Tech & Performance Forum 1 07 Jul 2011 01:16 pm
Gt Gauges thatsmrjptou Classifieds: For Sale/Trade 1 03 Feb 2010 11:29 am
What three gauges? 340X2C Tech & Performance Forum 2 06 Nov 2008 07:43 pm
Add-on Gauges Help 2K1Cruizer Tech & Performance Forum 2 03 Dec 2001 07:42 pm
