Battery cable connection help
Old 06 Jun 2014, 10:03 am
Default Battery cable connection help
Hello, I have an 06 pt cruiser touring with an automatic trans, and a major problem concerning battery connections. I have a battery wiring harness that contains an additional red wire coming off the negative terminal that i have no idea what to connect it to! I came into the repair after someone else had removed the cables and now I am lost. So... positive terminal is normal, 2 red wires, 1 to the starter the other to the pdc. The negative terminal however has 2 black, 1 going to the body the other connects at the transaxle where the trans dip stick assembly is bolted. the red one!!?? tried looking around to see where it could go, no luck. Car won't start but all lights and other electrical functions seem to work, battery drains quickly though. had battery tested, and its fine too. please help thanks
Old 06 Jun 2014, 10:46 am
Default Re: Battery cable connection help
No way should a red wire come off negative terminal unless someone did some really stupid wiring on their own. Red always denotes positive.
Give more information - was battery replaced?
Old 06 Jun 2014, 03:25 pm
You sure about that? Ever heard of reversing the polarity on a battery?
So if you were to have reversed the batteries polarity and continued to use the original connection then you would in fact have a RED wire on the negative lead.
Not recommended to try or that it applies to this thread.
Old 06 Jun 2014, 03:35 pm
JDB JDB is offline
Cat, my 06 only has 2 wires coming off the negative. One connects to the body next to the battery box and the other goes off under the box to...somewhere.
My guess, that red wire is NOT suppose to be hooked to anything. So try it without it hooked up to anything and if everything works...don't worry about it.
Old 06 Jun 2014, 05:28 pm
Post Re: Battery cable connection help
I'm telling you it's the most frustration I've experienced since before my puppy was potty trained. I'll take a photo. the car was bought last year for a ridiculously good price and it ran fine... the battery is not new. the cables were removed to gain accesss to a different component. this model has no positive jump terminal only shows a negative jump bolt. I looked at my 05 mustang to compare cuz i was shocked to see a red connector on it's battery negative post. the mustang also has a red cable on the negative terminal the 3rd cable on it goes to the starter. that's neither here nor there but it does happen obviously on some vehicles, this "3rd" cable
Old 06 Jun 2014, 05:40 pm
also, i have tried connecting that thing to anything I could find lol, I am not counting out the possibility of the previous owner trying to use the incorrect cable, that's likely, the car was certainly the dirtiest little thing I've ever seen. but why won't it start?? I could cry
Old 06 Jun 2014, 05:44 pm
ok scratch the part about my mustang having the red on negative terminal,I was mistaken. but i really would love to use a different negative cable for Petie (that's the cruiser's name) I am gonna just do it and stop whining about it, I've tried everything else!
Old 06 Jun 2014, 06:55 pm
After market remote start?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Battery cable problems. Ph0t0bug General PT Cruiser Discussions 0 09 Jan 2014 11:45 pm
Ground Cable Connection PianoTunerCruiser General PT Cruiser Discussions 5 01 Jun 2013 01:34 pm
Corroded battery cable QuarterFlash PT Cruiser Convertible Forum 7 26 Jul 2011 08:24 pm
Battery Cable Assembly... PTGirl2001 Tech & Performance Forum 0 19 Nov 2009 01:00 am
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
