Hi Members and Pros,
Trying to check my girlfriend's spark plugs on her 2006 PT Cruiser, 4-cylinder, 2.0 Liter, non-turbo and one of the first steps I'm told by the Haynes Manual before removing the upper intake manifold to get to the plugs is to relieve the pressure in the fuel system by disconnecting the fuel pump relay and running the engine until it stalls. However, everything I've read online and in the manuals state the relay is in the fuse box (integrated power module; or IPM) and none of the photos/layout match mine. I read some of the members here had the same problem when trying to figure out the fan relays. The relays in 2006's model I guess were not located right behind the air filter like instructed with Haynes (and yes it is the correct manual for 2001-2010). So does anyone know where the fuel pump relay is located for these odd 2006 models and do I really need to be worried about relieving the fuel pressure in the system simply to remove the upper intake manifold and spark plugs? I've never relieved the pressure on my 2000 eclipse to remove the spark plugs. P.S. She has never changed the spark plugs (to her knowledge) and she was experiencing pinging/very rough idling (like a 2-stroke engine) as well as stalling. So I wanted to check the plugs but after all the reading on fuel pumps I'm beginning to think it could be a fuel pump or pump relay problem ultimately. |
you do not need to relieve the pressure or touch the fuel line. i recommend staying far away from the plastic hardline. people break them accidentally all the time. seriously, don't even touch it (: just pop the upper intake off and leave the fuel line and lower intake alone.
Thanks, I finally got the manifold off but did accidentally break some of the hard plastic line feeding the evap purge hose on top of the throttle body. It was simply dry and brittle.
It looks like one of the spark plugs blew out of the cylinder (maybe only 2 threads deep from the wear marks) and that's what made it sound like 2-cycle lawnmower. Now, all I have to do is remind her to complete the other recommended maintenance. ![]() Thanks again! |
Tags |
06 pt cruiser fuel relay, 2006 pt cruiser relay |
Thread Tools | |
Display Modes | |
fuel pump relay | izcom2002 | General PT Cruiser Discussions | 7 | 31 Jul 2014 04:39 pm |
fuel pump relay | jc1200 | General PT Cruiser Discussions | 1 | 23 Feb 2013 01:16 pm |
Fuel pump relay overheats | nastrk99 | Welcome New PT Cruiser Members | 10 | 19 May 2012 03:50 pm |
Fuel Pump Relay Location 06 PT | goboom2 | Tech & Performance Forum | 0 | 17 Dec 2011 03:13 pm |
Does PT Cruiser have Re-wire Mod for Fuel Pump like NSRT4? | soccrstar | Tech & Performance Forum | 0 | 24 May 2010 06:37 pm |
