Possible cylinder misfire and general rough Idling cause
Old 11 Jun 2014, 08:19 pm
podo2000's Avatar
Default Possible cylinder misfire and general rough Idling cause
I have been trying to figure out why my 05 na idles rough and is sluggish to throttle input when its cold. I was checking the oil level today and saw Oil around the filler. Pulled #4 plug wire ( left one when you are facing the car) and the entire plug well was full of oil. car does not burn oil - so it had to be oil spilt during oil changes. Anyway, removed the intake and cleaned out all the wells and plug wires. #4,3 were full of oil #2,1 had a little in it.
Now she purrs like a kitten and got some zoom zoom back. The rough idle is gone as well.
Maybe something everyone should check once in a while.
2004 PTGT 135Kmiles
Old 11 Jun 2014, 08:34 pm
Default Re: Possible cylinder misfire and general rough Idling cause
There are rubber seals in the valve cover for the spark plug "wells" and they go bad, letting oil from under valve cover enter the plug wells.
Old 11 Jun 2014, 08:39 pm
podo2000's Avatar
Yup saw those. My wires are new, less than a year old. Seems like they were not seated well when it was done. Had a shop do it
2004 PTGT 135Kmiles
Old 11 Jun 2014, 11:33 pm
Chriscokid's Avatar
I believe the rubber seals that he is speaking of have nothing to do with your new wires. They are a separate component. Let us know what you find out.
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 12 Jun 2014, 12:07 am
podo2000's Avatar
Ahhhh. I understand now. is there an easy way to check for that - other then seeing it the wells fill back up between oil changes ?
2004 PTGT 135Kmiles
Cylinder 3 misfire michalo187 Tech & Performance Forum 12 28 Jan 2017 09:30 pm
Cylinder Misfire OneLeggedPuke Tech & Performance Forum 7 03 Jun 2014 12:36 pm
New guy with problems--Cylinder 3 Misfire ChryselerPT2007 Tech & Performance Forum 0 15 Mar 2014 11:26 pm
Misfire In Cylinder 4 shoe989 Tech & Performance Forum 13 23 Feb 2011 03:56 pm
Cylinder Misfire TaylorMade Tech & Performance Forum 6 16 Jun 2005 05:01 pm
