TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING
  • 1 Post By RacerX125
Old 11 Jun 2014, 10:21 pm
Exclamation TAIL LIGHTS AND BRAKE LIGHTS NOT WORKING
So i was driving my 2006 pt cruiser the other night and i realized my brake lights arn't working ! But the top middle light works and the license plate bulb works ? so what could be cause the running/brake lights to go out ? im confused
helpp thanks !
Old 12 Jun 2014, 09:15 am
Default Re: TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING
When was last time you knew they worked? Often there is condensation or a leak in the taillight lenses and the water blows the bulbs.
First check is the bulbs, then examine the sockets, then get a multimeter and check for power at the sockets.
Old 12 Jun 2014, 05:12 pm
Hope its just the bulbs, Mine didn't work and it was the brake switch, it has 3 sets of contacts in it and it says on the switch cannot be reused. It is adjust one time after you put it on and thats it.
I took mine apart and studied it and was able to reuse it after reseting it
Dont know if I could explain how its done.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 12 Jun 2014, 05:13 pm
They are not expensive... maybe $15- $20
Check ALL Electrical systems for proper operation
sunroof
interior heater fan, AC interior fan controls, radio, CD, all windows, all lights, turn signals, speedometer, air bag for lights, seat belts, wipers washers, power windows, power locks and anything else you can think of.
73 Charger SE
01 Sebring flip
Old 12 Jun 2014, 05:51 pm
If his brake switch was bad then the running light will still light up and the top middle brake light works when braking so I think it cant be brake switch
Old 12 Jun 2014, 05:58 pm
Agree with you.
Old 12 Jun 2014, 06:17 pm
Remember its and 06. I think the third brake light is run through the ECU/PCM. My third brake light worked but my brake light didn't until I reset my brake switch (replaced)
Of course I bought two new ones and couldn't get the lights to work
until I reset the original switch
73 Charger SE
01 Sebring flip
Old 12 Jun 2014, 06:21 pm
Still even when having a bad brake switch the running lights on the back should still work. Both going out the same time is very odd not sure if the cruiser 06 uses the brake light fuse with the back running light. If the fuse is used by both then probably blown fuse
2005 PT Dream Cruiser - Brake and Tail Lights Stopped Working ArkansasTraveler General PT Cruiser Discussions 5 10 Aug 2015 07:42 pm
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
Tail Lights Not Working Sue General PT Cruiser Discussions 6 27 May 2011 11:00 am
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
