2001 pt non turbo 2.4 won't start
Old 14 Jun 2014, 08:42 am
Default 2001 pt non turbo 2.4 won't start
Hey everyone I could use your thoughts and comments from ya. I have a 2001 pt non turbo 5speed. I made a turn a couple weeks ago and it died and won't start now. It will turn over but won't start. I have changed the can shaft position, crank shaft position, coil, and changed PCM. I'm stuck and don't know what to do can y'all help me out please thanks in advance
Old 14 Jun 2014, 08:47 am
Default Re: 2001 pt non turbo 2.4 won't start
Your just throwing parts at it and throwing money away until you do some diagnostic work. What mileage do you have and have you changed the timing belt?
Old 14 Jun 2014, 03:08 pm
No not yet but will the timing belt stop you from having spark.
Old 14 Jun 2014, 03:17 pm
yes. it will never start with a broken timing belt.
remove the camshaft sensor and try to start it. if you see the magnet spinning, chances are the belt is still intact.
2016 Kia Soul Plus Black
Old 14 Jun 2014, 03:55 pm
randyincctx's Avatar
Lightbulb Re: 2001 pt non turbo 2.4 won't start
Remove the camshaft position sensor,look into the opening,and have someone try to start/crank it......See if the magnet is turning inside.
If the magnet doesn't turn while cranking,your timing belt is broken,or missing teeth.
Aka:~KILLER~
Old 15 Jun 2014, 02:26 pm
It does spin it just won't start like there is no spark
Old 15 Jun 2014, 02:28 pm
....and you don't have the engine light showing that would mean there's a fault code stored in the computer?
Old 15 Jun 2014, 03:01 pm
Its funny you mentioned you "made a turn and it shut off"
I had a neon ond one of the signs the fuel pump was going bad was a
hard left turn.
Do you hear your fuel pump run? Pressure?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 Jun 2014, 06:06 pm
It's also a sign that you have the problem that CREWZIN had with his . Check the wiring harness between the crank and cam sensor on the backside of the engine. It comes loose and rubs the axle or other parts.
Old 15 Jun 2014, 06:22 pm
Does the tank have gas?
2001 Cruiser won't start bettypreston60 Tech & Performance Forum 1 15 Feb 2014 08:22 pm
2001 PT cranks but won't start PT2001 General PT Cruiser Discussions 8 23 Oct 2010 10:41 am
Hot start issue with 2001 Rlundstrom General PT Cruiser Discussions 1 11 Oct 2010 02:52 pm
2001 pt not start'in bugsy1025 Tech & Performance Forum 2 23 Apr 2008 05:31 pm
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
