thermostat housing leak?
Like Tree2Likes
  • 1 Post By UptownSport
  • 1 Post By NitroPT
Old 16 Jun 2014, 08:57 am
Default thermostat housing leak?
hey all, hoping one of you can advise here. changed out my thermostat and now its slightly leaking from the housing bolts? im afraid to tighten them any more, already cracked the housing once :/ (yes its a new one haha) i tried to tighten them evenly, went back and forth between them a couple times.... thanks for any input...
Old 16 Jun 2014, 09:57 am
Default Re: thermostat housing leak?
i think i heard someone mention that even new they can sometimes be garbage.
try exchanging for another new one
or
re-inspect your work paying closer attention to the mating surfaces and alignment
or
use a little permatex on there. i used ultrablack because it say ultra and it's black. the orange is ugly and the blue is soft.
Old 16 Jun 2014, 04:19 pm
Did you replace the gasket for the t stat?
Old 16 Jun 2014, 04:42 pm
randyincctx's Avatar
Lightbulb Re: thermostat housing leak?
The new one isn't cracked,or the new one is the one that cracked?
If your trying to install one that's already been cracked....You need to replace it.
Remove,clean T-stat housing,install new gasket,T-stat,and T-stat housing(NOT cracked!),finger tighten both bolts evenly,then alternate tightening the bolts to 110 Inch/Lbs(NOT!-Ft.Lbs),then sit back and enjoy beverage of choice.
Aka:~KILLER~
Old 16 Jun 2014, 09:53 pm
UptownSport's Avatar
Every one of those water necks are severely corroded, both where it mates to the head and where the t-stat seats.
NitroPT likes this.
Old 17 Jun 2014, 10:36 am
yes of course i didnt try to reuse the cracked one, haha. its a new one. thanks for the ideas, ill try messing with it again it does not appear to be leaking at all from the mating surfaces however, its literally coming up through the back bolt. thanks for all the replies!
edit:
i think this may be my issue
Old 17 Jun 2014, 10:51 am
2step's Avatar
The first time I changed the thermostat I almost put the gasket in wrong. While I had the rubber gasket in my hand and trying to figure out if it went under or over the thermostat, It dawned on me that the gasket was slit, C-shaped and so went ON the thermostat. Installed properly it should seal both above and below the thermostat. There should be no leaks at all.
I vaguely remember something about a square notch or tab with some of the gaskets and/or thermostats, but I don't remember the details.
Old 17 Jun 2014, 11:12 am
yeah theres a notch in the housing and a tab to match in the gasket. it fit in very nicely, with the thermostat sitting in the slit of it. thats what i found strange, because its not leaking from the seal where the two pieces meet. that seems to be fine. its coming up from the rear bolt! :/ are the bolts the same size? i dropped and lost one, i brought the one i still had to the store to match it. the old one is the one i put in the back, thats leaking, the replacement bolt i put in front seems to have no issue.
Old 17 Jun 2014, 11:13 am
juss yuse losaa seeeler!!
LionPT likes this.
Old 17 Jun 2014, 11:27 am
Originally Posted by NitroPT View Post
^ i have a friend that does that. when we were changing the heads the ports looked like puckered b-holes
Car temp climbing after thermostat and thermostat housing replaced. superjew78 General PT Cruiser Discussions 23 04 Jun 2014 02:37 pm
I stripped my thermostat housing! OneLeggedPuke General PT Cruiser Discussions 8 23 Jan 2014 12:07 pm
thermostat housing gasket soyomb General PT Cruiser Discussions 4 06 Feb 2013 09:21 pm
Thermostat housing cowboyinboxers Tech & Performance Forum 11 20 Oct 2012 06:51 pm
01 leaking from Thermostat housing, Please help gdarst Tech & Performance Forum 11 06 Jan 2010 06:52 am
