PT 5 speed trans fluid??? ATF +4??????
Like Tree2Likes
Old 18 Jun 2014, 09:18 am
Default PT 5 speed trans fluid??? ATF +4??????
Book calls for Mopar MS9417 FOR MY 2001 5 SPEED TRANNY??
I been told its the same as ATF +4 FLUID??? is this right thought i"d check here first thanks
Old 18 Jun 2014, 09:49 am
Default Re: PT 5 speed trans fluid??? ATF +4??????
Yes, ATF +4 is what you need; get synthetic. My transmission fluid was changed (synthetic added) at Oil Can Henry's.
Old 18 Jun 2014, 07:32 pm
rcktpwrd's Avatar
Exclamation Re: PT 5 speed trans fluid??? ATF +4??????
In '01 Chrysler used a MOPAR only gear oil in the 5 speed transmission, it is only available at the dealer. There are no aftermarket equivalents. This oil was used in other MOPAR vehicles prior to the PT as well.
I bought 3 quarts a couple years ago to do a fluid change in mine, it was about $18 a quart some dealers were over $20 a quart!
Sometime in '02 they changed to ATF+4 as the gear oil in the manual transmission.
Joel
www.rcktpwrd.com
Old 18 Jun 2014, 07:47 pm
$9.80 a quart wholesale, full chemical synthetic. http://www.amsoil.com/shop/by-produc...Mtf?zo=1181889
2001 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [B]
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
Maximum Performance SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W30 Synthetic Motor Oil (OEFQT) Above 0 F......10W-30
Below 100 F......5W-30 [1]
Manual Transmission,A578 (5-SPD)......GLS [2]
All TEMPS......
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Automatic Transmission,41TE......AP4
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Fluids
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [3]
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [4]
[1] SAE 5W-30 is preferred.
[2] Mopar part no. 04874465 or equivalent product
formulated to meet MS-9417.
[3] Original factory fill MS-9933 which was used in some
1998-2001 models is superseded by Mopar ATF+4.
[4] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB, meeting MS-4574
Old 18 Jun 2014, 07:48 pm
rcktpwrd's Avatar
the correct fluid is
Mopar Manual Transaxle Lubricant PN: 04874465
found some on eBay for a good price: http://www.ebay.com/itm/Mopar-Manual...369786?vxp=mtr
Joel
www.rcktpwrd.com
Old 18 Jun 2014, 08:07 pm
After many hours of researching ms9417 I ulitimately ended up using pennzoil gm synchromesh fluid. It's an oil with an additive similar to the original fluid. The dealer tried to sell me atf4 and I passed.
Old 18 Jun 2014, 08:13 pm
See here:i killed it.
Old 19 Jun 2014, 04:35 pm
well my rapair book calls for the Mopar MS9417 so anyone know if thats oil or fluid? if it comes from Mopar?..I"ll check with the dealer if it snot to high..
Old 19 Jun 2014, 10:22 pm
UptownSport's Avatar
Neon used the T350 (same as PT) since late 93.
There were dozens, maybe hundreds of threads on trans fluid on the Neon forums, with all us monkeys swearing that they determined it must have (insert any given name) oil, and any other oil would cause catastrophic failure.
Yet, there were no lubrication related failures (except the differential, which failed no matter what lube was used)
Me? I use plain old ATF, and at 300,000 miles, perhaps it will be failing soon.
Old 19 Jun 2014, 11:15 pm
As I closely followed the "SOX and MARTIN" SS HEMI Cuda, Dusters some where along I read they used auto transmission fluid in their standard 4 speeds of the day. I miss those days of match racing.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
TRANS FLUID TYPE? ptTurbo528 Tech & Performance Forum 14 28 Sep 2016 12:02 pm
TRANS FLUID CHANGE ALBERT Feedback and Support 6 31 Aug 2012 10:16 pm
synthetic trans fluid ok? 85_305 Tech & Performance Forum 11 24 Jul 2009 11:41 am
trans mission fluid|? whipplep General PT Cruiser Discussions 7 30 Sep 2008 06:14 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
