Overheating AGAIN!
Old 19 Jun 2014, 10:52 am
Default Overheating AGAIN!
Hi everyone! I have been a lurker on this forum for a while now, and have learned a ton of information, so I decided hey why not create a profile?
I know there are a ton of "overheating" threads in this forum, and I searched for a while before posting because I don't want to post a question that has been asked a million times, but I am not finding what I am looking for.
I have a '03, and I have changed the radiator cap, had the thermostat changed a couple of months ago, the water pump was replaced a year and a half ago, and now it is overheating again???
My regular mechanic is out of town until next week, and his brother that he left in charge (who I believe is way less knowledgeable) told me that I need ANOTHER water pump. I asked him "Do they need to be changed every year and half? Because that was just replaced." And his response was yes, they go bad and have to be changed that frequently. Now, I don't know squat about cars, but I don't think that I need to be changing something like that every year and a half. (He is kind of an idiot to me anyways...)
I don't think that I have a radiator leak because it is still full, but I do see liquid leaking out from the bottom passenger side when I turn the car off. So my question is: Do I truly need another water pump or does the radiator have a crack? I tell ya -sometimes ignorance is not bliss....
Old 19 Jun 2014, 11:01 am
Default Re: Overheating AGAIN!
I don't believe a water pump is your problem. The timing belt, tensioners, and water pump usually are replaced together at 90-100K mileage intervals.
A leak could easily be heater hoses or turbo coolant lines in addition to the usual suspects.
Old 19 Jun 2014, 11:02 am
Water pumps are shaft driven so unless the bearing is failing or the gasket/seal is leaking they will continue to pump coolant even in a failing state.
The "mechanic" should be testing the cooling system pressure and also the radiator cap. Better shops can test the antifreeze mix. With a thermal gun you can see the operating temperatures across the radiator core for operating consistency. By reading the thermostat area you can also determine if the thermostat is operating reasonably as it should be.
Maybe a second opinion from a more experienced or trained "mechanic (better a Auto Tech) should be considered?
OH AND....
WELCOME TO THE FORUM
btw you do not have profile information created by you yet?
Old 19 Jun 2014, 12:33 pm
Thanks a bunch for the responses, they are appreciated.
I just bought a new radiator cap, and I dont think that the water pump is my issue either...I am definitely getting a second opinion...I wouldn't let him touch my car that day....I told him I would rather wait until his brother got back.
Oh and yea, let me go and finish my profile
Old 19 Jun 2014, 01:17 pm
The fluid under passenger side - that's clear, isn't it? If so, it is from A/C and is perfectly normal and harmless.
Is your engine fan working on both speeds?
Open hood, start engine, turn on A/C, see if engine fan is running - if not, there's your problem.
HELP! Car is still overheating. Epicbeans Tech & Performance Forum 5 28 Apr 2013 01:28 am
Overheating PT pablonadoe General PT Cruiser Discussions 2 18 Apr 2013 11:15 pm
Overheating PTmom Tech & Performance Forum 9 15 Sep 2012 04:11 pm
Overheating again wargamer6 Tech & Performance Forum 12 30 Dec 2010 08:09 pm
Overheating Once again!!!! thetinman General PT Cruiser Discussions 4 09 Jul 2010 04:23 pm
