Replacement Radiator Fan rubbing
  • 1 Post By Busted_PT
Old 23 Jun 2014, 11:06 pm
Default Replacement Radiator Fan rubbing
Car was running warm today. I checked the relays, they were good, fuses were good, but the fan never started. I picked up a replacement at Auto Zone, installed it and started the car. After it warmed up, the fan started and was rubbing against the radiator.
I removed the fan assembly again, reinstalled it, same result. It appears the fan was a wobble in it. When I spin it by hand, it moves, maybe a 1/16" ? The old fan spun very true, no wobble.
Am I doing something wrong or is a bad replacement unit?
Old 24 Jun 2014, 04:49 am
Default Re: Replacement Radiator Fan rubbing
The fan should not wobble. It's bad, take it back to where you bought it and have it replaced. Try checking the new fan before leaving the store.
Old 24 Jun 2014, 08:48 am
Planning on take it back out again tonight and returning it. The wobble isn't the blade moving because its loose. The fan itself seems to have a bend in it. What a pain!
Old 24 Jun 2014, 06:01 pm
If you had say a 1/2" wobble it shouldn't hit the radiator. They don't fit that close. You need to compare to the original and see what is different about it. I checked the one on the project car and I have a ton of space between the blades and the radiator. 1/16" wobble on a plastic fan is not at all uncommon.
Ray_Dockrey likes this.
Old 24 Jun 2014, 06:57 pm
Check to see if there is horizontal travel in the fan. If the armature is not assembeled on the shaft correctly you will be able to move the fan blade in and out and since its pulling air that would make the blade with motor shaft go toward the radiator.
I just checked an old one I have and there is no travel, in and out, if I push-pull the fan hub. If there is travel return it
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Radiator Fan Replacement Chaylt Turbo Performance 10 05 Sep 2013 07:16 pm
Radiator Replacement - Anything Else While I'm in There? bfdill Tech & Performance Forum 4 16 Feb 2013 04:39 am
Need help with radiator replacement icrshalot General PT Cruiser Discussions 12 10 Mar 2012 11:09 am
replacement radiator sandylolee Turbo Performance 1 05 Jul 2009 01:23 am
A/C Hoses rubbing on Radiator overflow hose Zedster Tech & Performance Forum 3 04 Sep 2008 07:14 am
