Having trouble with pulling off harmonic balancer
Old 25 Jun 2014, 08:30 pm
Default Having trouble with pulling off harmonic balancer
I'm having trouble getting the harmonic balancer off. I'm in the middle of changing out everything that comes in the timing belt kit, and I'm stuck at this point. I borrowed the Chrysler OEM puller from Autozone to get the pulley out. I'd say it's around 1/2 to 3/4 of the way off, but at this point it doesn't want to budge. The arms of the puller keep slipping off of the pulley the more I try to crank it at this point. I can't figure out why this is happening or how to fix it. Anyone have some advice?
Old 25 Jun 2014, 09:14 pm
Default Re: Having trouble with pulling off harmonic balancer
I've done several and always used an impact gun, sometimes a torch to heat up the center hub if it seemed stuck and I always remember putting little wedges behind the arms of the puller because they seem to want to slip out.
use the tips of screw driver maybe.
Make sure your pulling straight, In the kit I borrowed from Advance Auto the pin supplied with the kit to push off the harmonic balancer doesn't seem to be the correct one. Cannot remember , to long or to short so I made one I use too. Make sure the center push bolt is not bottoming out. You might need a longer pin.
Usually the hardest part is getting it to move as you first start pulling.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 26 Jun 2014, 06:47 am
Post a pick where the puller and the center hole meet. At that point you should be able to get it off if the puller is set up right. You might be pushing against the pulley itself. Instead of the center rod.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
JoeX likes this.
Old 27 Jun 2014, 07:50 am
Thanks for replying. I figured out how to get it out. I had to take a 2-3" pipe clamp and tighten it down around the puller arms to keep them from slipping out. Also to note, the puller was bottoming out even with the longest extension. It turns out that you have to flip the arms over on the puller and use it so that the flush side of the puller is what you are screwing down to. The other side has a ridge that you screw down to, and I was having the problem where I bottomed out on the puller and still didn't have the pulley off. Basically, have the side of the puller without writing facing me. On towards the timing belt. Oh, also do I need to disconnect the exhaust for this?o
Old 27 Jun 2014, 12:46 pm
The puller I used can't slip out so I didn't have any problems. Glad you are making progress.
Old 27 Jun 2014, 12:59 pm
I paid to have mine done, but I have never heard of needing to bother exhaust to replace timing belt.
Old 27 Jun 2014, 05:24 pm
Yes it's way easier to move the engine up and down if you disconnect the exhaust from the manifold.
Old 27 Jun 2014, 05:51 pm
on a turbo car. on an NA car you're just making more work. i've had to raise/lower the engine for both the timing belt and the clutch and i've never touched the exhaust. that just sounds like one of the many useless extra steps you'd see in a chilton manual.
Old 02 Jul 2014, 05:28 pm
I disconnected the exhaust, and that did help. Now, I just can't get clearance to get that metal bracket out. More specifically, I cannot get 2 of the 3 15mm bolts out of the metal plate due to lack of clearance. I can't get that motor mount that is in there next to it either. It seems that I can't move the engine up or down enough to get enough clearance for the bolts to come out. I'm not sure if I missed something or what. Does anyone have an idea?
Old 02 Jul 2014, 05:53 pm
You will have to loosen them and use the socket by hand until you can get hold of the bolt to screw them out. Don't think you can get that center mount out of the rail. If the rubber isn't tore just use it.
How to remove Harmonic Balancer? TeddoNawthCaroliney Tech & Performance Forum 17 04 Mar 2017 10:47 pm
Harmonic balancer removal Carl48 Tech & Performance Forum 6 06 Nov 2013 02:19 am
harmonic balancer Jassy General PT Cruiser Discussions 2 01 Jan 2012 12:26 pm
harmonic balancer (or what ever yall call it) mdskinner731 Tech & Performance Forum 4 16 Nov 2011 04:25 pm
harmonic balancer mdskinner731 Tech & Performance Forum 10 15 Sep 2011 09:04 am
