Flashers/Blinkers not working from switch.
Like Tree3Likes
  • 3 Post By ChazBOT
Old 26 Jun 2014, 09:31 pm
Default Flashers/Blinkers not working from switch.
Hello again new PT friends! My PT cruiser keeps blowing a fuse as soon as I turn on the flashers or use the blinkers. They come on and flash when I use the key less entry, but that is about it. I have replaced the blinker switch and it keeps happening. Any thoughts on this? Driving me crazy!
Old 27 Jun 2014, 08:48 am
Default Re: Flashers/Blinkers not working from switch.
Have you replaced the multifunction switch - the lever? That's probably got a short. You replaced the blinker module that plugs in, right? That's probably okay...
Old 27 Jun 2014, 09:11 am
Please tell us which fuse is blowing. This helps troubleshooting. Clearly the wiring from the RKE to the (parking) light bulbs is OK.
The flashers operate on a different circuit through separate filaments so the lock/unlock light flash signal is a red herring.
(parking
Old 27 Jun 2014, 10:01 am
randyincctx's Avatar
Lightbulb Re: Flashers/Blinkers not working from switch.
If the fuse that keeps blowing is fuse #18,here is a PT Cruiser with a somewhat similar issue(w/lots of good wiring schematics there):http://www.justanswer.com/chrysler/4...ser-blows.html
You probably should thoroughly inspect the wiring for the MFS connector plug,and the wiring on the back of the fuse block to see if there are any signs of overheating(melted/burnt).....Because it sounds like your getting a ground fault/short somewhere along the pathway of the turn indicator circuit.
Here is a 'pin-out' diagram for the MFS connector plug:
Aka:~KILLER~
Old 27 Jun 2014, 03:27 pm
FIXED!!!!!
So I yet again replaced the flasher 15 fuse,blinker switch and flasher (relay? goes on the back of the switch.) and now they work. I might have gotten 2 bad switches or a bad relay last time.
Old 28 Jun 2014, 08:42 am
Thumbs up Re: Flashers/Blinkers not working from switch.
That does happen......Glad you got it fixed.
Aka:~KILLER~
Old 29 Jun 2014, 11:41 pm
Thank you everyone for the help!
Stereo not working after replacing Multifunction Switch talows Sound and Security Forum 0 11 Mar 2014 09:31 pm
HELP!! lights, blinkers, & wipers all not working capo General PT Cruiser Discussions 11 26 Jun 2013 09:41 pm
dome light switch on S/W not working outfit Interior Accessories Forum 0 13 Dec 2010 04:17 am
Blinkers and Hazards not working badgingles Tech & Performance Forum 1 03 Sep 2009 08:55 pm
door lock switch not working ptbooga General PT Cruiser Discussions 2 08 Oct 2005 06:00 pm
