2001 Limited Ed PT with maybe bad oil pump- please help.
Old 27 Jun 2014, 11:19 pm
Default 2001 Limited Ed PT with maybe bad oil pump- please help.
I have a 2001 PT- Inferno Red Limited Edition with 168,800 miles. I love this car!!! I am the second owner and bought it with @24000 miles on it in 2003. The same shop works on the maintance work- I have regular oil changes and tire rotations, timing belt, shocks, etc.
Last summer I had to have the head gasket repaired- my regular mechanic does not do in depth work like that and outsourced it to another shop, that they recommend all the time. As soon as I got it back it had a vibration that it didn't before- like a fast idle. I have taken it back 4 times now for the same vibration - of course the noise and vibration are gone when the mechanic drives it.
On Thursday - I took son's girlfriend to work - on the way the noise and vibration started up. The engine develops a roaring noise, the wheels start to chatter and the steering wheel vibrates like crazy. If I slow down ( stoplight/ stop sign ) the noise and vibration goes away. Except yesterday- after dropping off girlfriend - the vibration came back and the car started to lose power and the oil light came on and dinged. I thought I might be able to make it back home ( 5 miles ) but then I started to loss power again. I managed to pull into a BP/ quick stop. Called hubby and a tow truck. Took it to mechanic.
Today the car started up fine and drove fine- oil level is fine, compression is fine, car has no vibration and no engine noise. Mechanics ( who works on this car ) thought it might be the oil pump going bad - of course they do not do that level of work. He is bothered by the fact that the issues started after the other shop did the work and after 4 tries can not pin point the issue.
So any clues???? I could really use some advice here. If it is the oil pump - I would have to find a reliable shop or take to dealership.
This car has never given me any trouble - I have driven it NC - Michigan and back - to Alabama- Pa, FL and it has never let me down.
Outside of the head gasket and an entire AC replacement - no other problems with the car
Old 28 Jun 2014, 05:17 am
Default Re: 2001 Limited Ed PT with maybe bad oil pump- please help.
You might want to have your mechanic check all he motor mounts and replace the Oil Pressure sensor. Both those things have been known to cause trouble. Other places to check are the front wheel bearings and drive axles. At your mileage all the above things I've mentioned (except maybe the axles) are probably due for a change. For the fast idle, have someone look over all the vacuum lines for bad connections, leaks and splits in the rubber hoses.
Old 28 Jun 2014, 09:06 am
Hi- the wheel bearings have been replaced, the motor mounts were checked for the vibration a couple of different times.
The reference to fast idle is what the engine sounds like when the vibration starts up. Normally - the engine is quiet.
It is very frustrating - since it does not happen on a regular basis.
Old 30 Jun 2014, 11:04 pm
Oil pump rarely goes bad, and if it did, I cannot see it causing a noisy vibration, and it would be constant.
The Oil sensor does go bad. Cheap to replace.
I'm thinking Idle Air Controller may need cleaning - it could be sticking.
2001 oil pump jc_89 Tech & Performance Forum 5 22 May 2013 09:06 pm
2.4L 2001 - Replacing Water Pump timbogates Tech & Performance Forum 14 24 Apr 2013 02:55 am
2001 oil leak/oil pump steveiej1970 Welcome New PT Cruiser Members 6 05 Dec 2011 01:18 am
2001 PT overheating! Is it the water pump? fduffy28 Tech & Performance Forum 14 03 Apr 2011 10:53 am
Changing Water Pump in '02 Limited Edition... missingwhatsnear Tech & Performance Forum 2 12 Feb 2009 05:06 pm
