2001 PT Cruiser
Old 30 Jun 2014, 03:46 pm
Angry 2001 PT Cruiser
I have been getting the error code P1684. Car won't start. Already t ia new Starter put in a while back. Usually will start when left overnight, but now it won't start. Any suggestions.
Old 30 Jun 2014, 04:10 pm
Default Re: 2001 PT Cruiser
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
Check the battery for full power and good connections (no corrosion), coil/plugs for spark. The 2001 has a Schreoder vlave at the end of the fuel rail to check for fuel pressure.
Old 30 Jun 2014, 10:18 pm
So, starter cranks, but engine doesn't catch?
No other error codes?
How long has gas been in the car? Does car get driven much?
How many miles on the car?
When were plugs and wires last changed?
2001 PT Cruiser sgoodyear Tech & Performance Forum 4 24 Apr 2014 08:39 pm
2001 PT Cruiser JLauruska Welcome New PT Cruiser Members 2 03 Sep 2013 08:29 pm
2001 pt cruiser jdp01 General PT Cruiser Discussions 1 08 Jul 2009 02:48 pm
