Solution for codes 355 and 344
Old 02 Jul 2014, 12:36 pm
Default Solution for codes 355 and 344
GROUNDING!
The point of this post is to illustrate the importance of good grounds when you are getting sensor problems. Its a super-cheap fix before you start throwing parts at a problem.
I fought with this for about a month - I got codes 344, replaced the cam sensor, then 335, replaced the crank sensor (both with dealer parts) and it didn't change. Then I started getting 300 (random misfire) 304 (bank 4 misfire) and 2074 (mismatch between MAP and TPS sensor readings). By the end, I swapped out the cam and crank position sensors, map sensor, coils, ecu, plugs, and plug wires.
When looking through everything I found that the ground from the battery to the body had broken off. I reattached it, but everything was so corroded that it didn't make a difference. I ended up running a new ground to the starter/engine block and both locations when the multiple ground wires connect. When doing so I cleaned the locations where they made contact with a wire brush to get rid of any thing underneath. Once done, it worked great!
Old 02 Jul 2014, 01:19 pm
Default Re: Solution for codes 355 and 344
Thanks for your post. Yes, there's been many posts about the importance of all the ground wires on the PT. Here's one that covers the ground wire in the wheel wells and on Hyper Grounding......
ground wires from body to front struts?
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
A/C Issue - Solution with Your Help! ewhenry General PT Cruiser Discussions 3 23 May 2009 06:14 pm
PO325 solution? ptborder Tech & Performance Forum 2 28 Mar 2009 06:53 pm
The Cap Clip, gas cap solution! Got My PT Vendors & Buyers Forum 0 16 Mar 2002 03:39 am
