Cooling Fan Woes
Old 02 Jul 2014, 02:45 pm
Default Cooling Fan Woes
My first post under this user name, been here before.
This one is crazy. My PT started to overheat on local roads, highway
travel at a steady speed is OK, right in the middle. I did some research
and things pointed to the fan. I was able to get the fan assembly out
after some struggling and colorful language. Started the motor and let
it heat up, no fan. Couldn't get the connector undone so I striped some
insulation and did a direct to the battery. There are three wires on the
fan side, two blue, one black. I assumed black was ground. Positive
wire to the right blue wire, negative to the black. The fan spun but the
wire got red hot. Next, positive to the left blue wire, negative to the
black...nothing.
So, what is it? Relays, fan motor, something else? I would like to have
an idea before I start replacing stuff. Finally got the connector undone,
the release tab was gone.
Thanks in advance!
[IMG][/IMG]
Old 02 Jul 2014, 03:06 pm
LionPT's Avatar
Default Re: Cooling Fan Woes
New here....and a question
Old 02 Jul 2014, 04:27 pm
Thanks for the response.
The high speed wire ran the fan when jumped to the battery. The low speed wire never ran when jumped. Neither low or high speeds run when the engine is hot.
Old 02 Jul 2014, 04:37 pm
LionPT's Avatar
I believe the high speed fan only runs when the A/C is on.
Your going to either have to buy a new fan or hotwire the high to run all the time...but I don't know how long that will last.
Old 02 Jul 2014, 04:52 pm
The high speed will run without the A/C. You just have to have the coolant hot enough so the ECT tells the computer to turn it on.
Old 02 Jul 2014, 05:27 pm
I had the temp over the 3/4 mark, no fan came on.
Old 02 Jul 2014, 05:33 pm
Then you possibly have another problem either with the ECT, relay or computer.
cooling fan woes. Searched, tested and inspected everything. traikun Tech & Performance Forum 14 22 May 2014 08:11 pm
PT woes Stuart_L Tech & Performance Forum 17 02 Feb 2014 09:44 am
A/C Woes..... selkov Tech & Performance Forum 0 10 Jun 2013 10:53 am
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
A/C woes!!! brknn45 General PT Cruiser Discussions 2 16 May 2013 06:03 pm
