Another A/C overheat
  • 1 Post By JoeX
Old 02 Jul 2014, 08:49 pm
Default Another A/C overheat
Wifes 04 turbo light started getting hot when the A/C is on. Its recently had a thermostat and doesn't over heat when a/c is off. On cold start, the fan is off with a/c off and kicks on right away when you turn on the a/c. I disconnected the fan and was able to get both speeds to kick on with jumpers. I replaced the high speed relay also. Whats left to check or replace?
Thanks
Old 02 Jul 2014, 09:17 pm
Default Re: Another A/C overheat
Radiator Pressure cap - its 10 years old
electrical connectors- examine where they go together and make contact
fluid level
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Jul 2014, 08:25 am
fluid level
Also a radiator flush - might be crud in radiator. This is particularly likely if temp rises even at highway speeds.
Remember, when A/C is put on, it's because it's hot out, so it's an extra load on cooling system...
Intermittent overheat slipperyrock General PT Cruiser Discussions 4 02 Apr 2013 06:52 am
Overheat issue hinesv Tech & Performance Forum 6 11 Nov 2012 02:49 pm
How not to fix an overheat problem!! 767skyking Tech & Performance Forum 16 07 Aug 2012 04:12 pm
Another Overheat PT PTJohn Tech & Performance Forum 4 15 Sep 2011 12:53 pm
overheat onyx pt General Turbo Discussions 11 27 Nov 2006 10:55 am
