Battery drain question
Like Tree4Likes
Old 06 Jul 2014, 08:06 am
Default Battery drain question
My wife went out to start our 2004 Turbo lite the other day and was met with 'clicking'. The battery jumped fine and the car seemed ok, but the battery didn't seem to charge in driving around.
I pulled the battery and had it slow-charged overnight, after which is checked out as ok on advance auto's tester. I reinstalled it and had advance run their charging system check on it.
The charging system check didn't detect any issues, but I thought it was strange that it could not detect the engine revving.
The battery has no drained again to the point of clicking when the key is turned. The cables are corroded as others have discussed here before - should I change them or just go straight for the alternator, assuming it's an open diode causing the drain. We haven't had any phantom drain in the past and the lights have not been on. I replaced the multi-function switch last year so it isn't the fog lights.
Any ideas would be appreciated.
Old 06 Jul 2014, 09:57 am
Default Re: Battery drain question
so I've done some more reading and it seems that the fact that the charging system test said that there wasn't excessive ripple indicates it's probably not the alternator. Given the known issues with the battery cables and the obvious corrosion I guess that I need to change those first and hope that there isn't some evil electrical gremlin hiding somewhere.
Old 06 Jul 2014, 10:04 am
In the past when there was an open diode in the alternator it would not charge but it didn't seem to drain the battery unless driving and that was from the no charging condition.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Jul 2014, 01:38 pm
I'd still pull the foglight fuse temporarily to rule them out...
Concentrate on cable to starter.
randyincctx likes this.
Old 06 Jul 2014, 04:31 pm
randyincctx's Avatar
Question Re: Battery drain question
I second that!....Question: Have you checked to see if your fog lights still work properly?
I ask that because,even though the fog lights may not be 'on',there have been some instances of 'parasitic drain' caused by the MFS,even though the fog lights were not turning 'on'.
A couple of those with that issue turned out to be an overheated wire(or wires) in the MFS @ the connector,and NOT the MFS itself......So,you may want to remove the steering column shroud,and take a close look at the connector.
Your MFS connector may not look as bad as the photos below,but even a small amount of overheating can cause an issue,such as a 'parasitic drain':
These 2 photos are actually of an SRT4,but they use the same MFS connector as PT Cruisers:
Aka:~KILLER~
Old 06 Jul 2014, 10:05 pm
Wow! I tried the fog lights and they didn't work at all. I tried to measure the draw using my multimeter and it seemed that pulling the fuse may have done the trick. I guess I'll have to replace the switch. Again.
Old 07 Jul 2014, 10:19 am
Lightbulb Re: Battery drain question
You might want to have a go at repairing your current MFS,and you may end up with one that's better than even a new one;But you may still discover it's the connector once you tear into it.
Here's some great MFS threads to check out:
How to Repair the Multifunction Switch w/ Pictures (Fog Lights)
The "Handy" Aluminum Can Mod To Fix Fog Lights.
If it does turn out to be your connector,which is somewhat common(alot of PT's have these burnt).
There's supposedly a replacement for those also @ RockAuto:
Search part# 1P1610
AIRTEX / WELLS Part #1P1610 cost= $64.79
Info: More Information for AIRTEX / WELLS 1P1610
If ordering anything from RockAuto(MFS,Wiring Connectors,Etc.),they have recently posted a thread offering a 5% discount on any purchase:
RockAuto Discount Code - Expires 09/18/2014
Aka:~KILLER~
Old 13 Jul 2014, 04:56 pm
I can't find anything wrong with the mutli-function switch. I have no idea why the fog lights aren't working, as they used to after I replaced the switch last year.
So what is the deal with battery cables? My PT is a turbo-lite. The battery cables the dealer specs are a $400 wiring harness. Any idea what the difference is between the different engine's battery cables? The battery cable assembly for a non-turbo costs $60 online.
Old 16 Jul 2014, 08:53 am
Wow.
I started messing around with my new auto ranging digital multimeter last night and quickly found that there was a 0.05 amp draw only when the parking light fuse was installed.
I tried to charge the battery and it wouldn't take a charge. I walked it to advance auto and surprise surprise it tested as bad. Installed new battery and drove to work. Nifty new multimeter tells me that alternator is ok, battery is holding charge as long as the parking light fuse is out.
Old 16 Jul 2014, 09:02 am
Can't see .05 amp draining your battery - even overnight..
5 amps, yes.
Probably have some corrosion allowing the .05 amp drain...
Fog Lights Stay on, Drain Battery Shellhead General PT Cruiser Discussions 14 16 Jul 2013 11:15 pm
Battery Drain bmeador55 Stage Turbo Kits 2 10 Jul 2013 09:04 pm
Battery Drain Question PTFlorida Tech & Performance Forum 14 18 Nov 2012 08:46 am
Battery Drain ??? Derrick Tech & Performance Forum 18 28 Feb 2010 07:44 pm
Do lights/lighter drain battery to death? zzzhuh General PT Cruiser Discussions 11 04 Mar 2004 08:11 am
