Overheating. again.
Old 07 Jul 2014, 11:34 am
Unhappy Overheating. again.
I have an 04 non-turbo. Last week it began to over heat. I tested the fan because I could not hear it kick in per normal. Fan did kick on with direct power from a 12v source. I replaced the coolant temp sensor. This seemed to solve my issue. The fan kicked in. well.... one week later. Same issue, Overheating, and I don't hear the fan kicking in. I turned the ac on and let it run then got out to check the fan. The ac ran for about 2 minutes tops, and when suddenly it blows off pressure from a dump valve (scared me to death BTW). I shut the AC off, repeated it. it dumped again. I don't even know if the two issues are correlating. I just don't know. BTW there is no check engine light. can anyone help me out? I don't have a clue.
Old 07 Jul 2014, 06:49 pm
Default Re: Overheating. again.
Check the connector from the fan wiring harness, it could be a loose connection damaged from heat. And if the fan is10 years old I'd bet the brushes make contact with armature sometimes.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
overheating ratcruizr Tech & Performance Forum 2 04 Apr 2014 08:56 am
overheating bheffner General PT Cruiser Discussions 3 10 Sep 2013 09:32 pm
Overheating PT pablonadoe General PT Cruiser Discussions 2 18 Apr 2013 11:15 pm
Overheating PT GT Fuct General Turbo Discussions 4 04 Aug 2011 04:46 pm
Overheating kporcenaluk Tech & Performance Forum 5 01 Sep 2010 08:48 pm
