01 limited overheating
Old 07 Jul 2014, 09:52 pm
Default 01 limited overheating
my wife loaned her pt to her sister for about a month we got it back with rusty water stains under the hood, on the hood ,on the fender and windshield she denies that it ever ran hot. took it home and found the fan not working. I replaced the fan, thermostat (stant superstat), radiator cap , checked all hoses, checked for leaks and made sure all air was out of the system. now it runs good for about ten miles and runs hot. very hot very fast. when it starts getting hot it will go from normal to hot enough to blow the water out of the overflow within 2-3 minutes. and sounds like water boiling inside the engine. any suggestions on what to check next would be much appreciated.
Old 08 Jul 2014, 06:48 am
LionPT's Avatar
Default Re: 01 limited overheating
Not that you want to hear this, I had the same problem...it ended up being a blown head gasket.
Old 08 Jul 2014, 09:04 am
thanks for the reply. that's what I was expecting to hear, now I need to find a good shop and have it checked its also past time for a timing belt, water pump and tune up. hope it don't cost more than the car is worth.
Old 08 Jul 2014, 10:21 am
Look in radiator - is coolant murky? Brown foam under oil filler cap?
Head gasket would account for your symptoms.
Labor is about the same whether you need head gasket or just timing belt/water pump/tensioner, but head will have to be checked for no warping, and the head gasket will add to the cost.
Old 08 Jul 2014, 10:45 am
Divide the cost by 12 and see if you can pay a payment that cheap. Then think of what it cost a month for two years. Heck you pobobly loose more than that driving off the lot in deprecation plus you still have the big payment.
So how much is really about the cars worth versus cost per month to drive?
Old 08 Jul 2014, 10:47 am
no oil in water or water in oil, oil cap and dip stick clean, water in radiator very rusty. i'm going to flush cooling system and replace thermostat again before taking it to the shop.
Old 08 Jul 2014, 11:37 am
LionPT's Avatar
I didn't have any fluid transfer in mine either...I replace the thermostat also I planned on doing the flush...but had a gut feeling it was something more.
Maybe you'll have better luck.
Old 11 Jul 2014, 02:26 pm
flushed the cooling system today and replaced the thermostat. both engine and radiator were very dirty lot of rusty water. drove the car for about 8 miles with no problem . I will drive it for about a week to make sure before I give it back to my wife.
Old 22 Jul 2014, 04:18 pm
after a complete flush of the cooling system (both engine and radiator) and new t,stat I have drove the car close to 200 miles with no overheating or water loss, now to flush again ,remove water and add coolant. thanks for all the help on this forum.
Old 24 Jul 2014, 05:43 pm
guess I spoke too soon about my cruiser overheating . while out shopping for tackle my cruiser ran hot again , went to 3 sporting goods stores and stopped to get something to eat ,while waiting at the drive thru it ran hot very hot very fast . from normal to the light flashing and the bell dinging in less than two minutes. now to decide whether to fix it or part it out.
Overheating 2003 Limited Drakkun Tech & Performance Forum 24 15 Feb 2014 04:29 am
Overheating 2002 PT Limited tdkmpeak Welcome New PT Cruiser Members 10 19 Aug 2013 07:20 pm
Overheating Help!! Seedman14 Tech & Performance Forum 20 14 Jul 2012 08:14 pm
Overheating '01 Limited vadutchgirl Tech & Performance Forum 10 21 Jul 2009 01:35 pm
01 Cruiser Limited Overheating + No heat Jager Tech & Performance Forum 1 17 Apr 2009 07:34 am
