bumpy road with newly purchased 2001 pt cruiser limited
Like Tree4Likes
  • 2 Post By Busted_PT
  • 1 Post By Busted_PT
  • 1 Post By randyincctx
Old 08 Jul 2014, 12:12 pm
Default bumpy road with newly purchased 2001 pt cruiser limited
I've been all over this board trying to figure out the issues of my newly acquired '01 pt cruiser. I'm going to start from scratch and see if someone here can help me. T
*Test drove the car ran good and tight, seemed solid. *Realized that if it sat for a while running it began to overheat. But I paid $1000 for it and decided to fix it.
*replaced thermostat and radiator first
*upon starting it, Coolant spewed under hood on passenger side.
*tore down and replaced idle pulley timing belt and water pump (also realized that spewing Coolant was probably coming from thermostat I replaced but didn't get a good seal on
*put car back together and note no overheating problems but now it
*IDLES ROUGH
*DIES WHEN IDLING TO LONG
*GETTING TERRIBLE GAS MILEAGE
I did also replace the map sensor that was looking a little rough.
Its not at all smooth and tight like it was before I worked on it.
Please help me figure this one out
Old 08 Jul 2014, 01:31 pm
LionPT's Avatar
Default Re: bumpy road with newly purchased 2001 pt cruiser limited
Post #2
2004 PT Cruiser Transmission problems?
Old 08 Jul 2014, 01:37 pm
*IDLES ROUGH
. Sounds like a timing issue. Pros at Chrysler dealers have gotten this wrong. Cooling fan not kicking on can cause over heat.
Old 08 Jul 2014, 02:46 pm
Originally Posted by Lion7718 View Post
I have done the key dance, i get P0108 p1297 p0108 p0108
Old 08 Jul 2014, 02:50 pm
Overheat problem is fixed. Like i stated, That was the radiator/thermostat.
Then replaced water pump pulleys and timing belt. Now car dies when idling to long and gets bad gas mileage. Is it something I did when fixing other repairs?
Fans are working properly.
Old 08 Jul 2014, 02:59 pm
LionPT's Avatar
P0108 & P1297 are both MAP Sensor codes.
Old 08 Jul 2014, 03:00 pm
Like I said it's out of time on the timing belt.
Old 08 Jul 2014, 03:29 pm
I was afraid of that. Is there any chance, since the map sensor was bad, that the throttle position sensor could also be bad?
Or just suck it up and redo the timing belt?
Old 08 Jul 2014, 03:37 pm
If it idled smooth before then you have to check the work already done. you can take pic to confirm with us before you get to far back together. You can start it with it open no balancer to check for smooth idle also.
mrstolleson likes this.
Old 08 Jul 2014, 08:48 pm
randyincctx's Avatar
Lightbulb Re: bumpy road with newly purchased 2001 pt cruiser limited
Yeah,you should have come here first(B4 doing T/B),just to confer,and make sure you had it 100% correct.....Even being 1 tooth off,can cause the symptoms your describing,and this can happen upon tensioning the belt,so you kinda have to compensate for that when tightening it down.
Everything should be lined up like this(see photos),after the proper tension has been applied to the belt:
Busted_PT likes this.
Aka:~KILLER~
Tags
gas mileage, rough idle
2001 pt cruiser, road trip. juber0 General PT Cruiser Discussions 4 18 Mar 2014 12:52 pm
Just purchased a 2001 PT Ftauto Wheels, Tires, Suspension 4 17 Jan 2013 09:03 am
Newly purchased 2003 PT Cuiser Turbo ptbetty Tech & Performance Forum 3 14 Jun 2010 02:34 pm
Just Purchased 01 Limited PT - HIGH MILAGE pasikobri Tech & Performance Forum 2 25 Jan 2010 11:19 am
out of curiosity banging on bumpy road chryslergirl Tech & Performance Forum 2 14 Jul 2009 06:58 am
