p028
Old 09 Jul 2014, 07:29 pm
Default p028
what does the code p0128 mean?
Old 09 Jul 2014, 07:38 pm
Default Re: p028
It probably should read P1028 and it's for the Oxygen sensor.
You never did introduce yourself to the forum after you last question or thank anybody for the information that they gave you to your question.
Old 09 Jul 2014, 07:39 pm
Default Re: p028
i've NEVER seen that code come up here. but looking it up i see this:
A code P0128 may mean that one or more of the following has happened:
Low engine coolant level
Leaking or stuck open thermostat
Faulty cooling fan (running too much)
Faulty coolant temperature (ECT) sensor
Faulty intake air temperature (IAT) sensor
Read more at: OBD-II Trouble Code: P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
Copyright OBD-Codes.com
