VERY loud moaning & groaning after a complete stop
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By Danny7627
Old 11 Jul 2014, 08:49 am
Default VERY loud moaning & groaning after a complete stop
We're having a tough time with this, because the problem seems to disappear whenever we drop the PT off at the local shop. I think there is something wrong with the front brakes; here are my symptoms:
• VERY loud moaning, or groaning, metal-on-metal rubbing when coming out of a stop; sound is coming from the front of the vehicle
• Step or tap on the brakes, the sound stops immediately, then resumes when brakes are released again
• Stand on the brakes a while, as at a prolonged stop, and it’s more likely to happen; the longer you stand on the brakes, the more likely the moaning/groaning is to occur
• Eventually, the noise will stop, but can start up again next time brakes are applied.
The Cruiser is a low-mileage 2000 (I want to guess 70K [it's not my car]), and this has never happened before. I've read that these brakes can get a build-up of crud that needs to be washed out, but the mechanics have never heard of such a thing.
Clearly, I'm not a mechanic, but it seems to me as if the brakes aren't releasing properly—like someone pressing both pedals at the same time.
Old 11 Jul 2014, 09:25 am
Default Re: VERY loud moaning & groaning after a complete stop
Sounds like what you have said; brakes not releasing and if it's metal to metal your hearing, they should be pulled apart and inspected. Take a good look at the anti-rattle clips also. The only "crud" that I know of that builds up is with the drum brakes in the rear and it's usually a squealing noise.
Old 11 Jul 2014, 09:31 am
Danny7627's Avatar
Definitely check the brake pads and rotors.
However, it sounds more likely to be the front wheel bearings from the noise you described.
Here's a link for front wheel bearing replacement. The symptoms sound similar.
Good Luck
Danny
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 11 Jul 2014, 11:16 am
I love those videos; when I watch them, I think, "I can do that!" But it would take a stick of dynamite to move me to tear the wheel off one of my cars by myself. I shoulda had one of those dads who would bring me into the garage to work on the family car by his side.
Anyway, the front brakes were locked. The mechanics discovered it when they went to replace the pads. We were basically driving around with the brakes on. We're off to pick it up right now.
I'm still curious as to why this happened. I'm more than a little surprised the mechanics didn't guess as much earlier, though we were less accurate in describing the symptoms last time we dropped it off (we thought it was happening in turns, not realizing it was happening after using the brakes).
Thanks for all the input—you guys are the best car community in the world!
Old 11 Jul 2014, 11:33 am
LionPT's Avatar
I'm guessing the piston got stuck, so they replaced the caliper.
Old 11 Jul 2014, 12:18 pm
Agreed - and a sticking piston is pretty much random.
Old 12 Jul 2014, 09:40 am
It can also be caused by a bad brake line. The flexible line can break down inside preventing the caliper from releasing. This is made worse at time when bad garage monkeys bend them too much when removing the caliper, or worse, pinching them with vise grips when removing the line from the caliper to prevent fluid from leaking out. I have seem many "mechanics" do this.
Simple age can make this happen of course, and they will look fine on the outside. They are simple and cheap to replace.
Groaning sound after complete stop jillymae11 Tech & Performance Forum 9 12 Aug 2012 07:53 am
Clunking / Groaning When I Turn AllisonInVirginia Wheels, Tires, Suspension 1 16 Dec 2011 11:48 am
My car is moaning at me!! insanepagen PT Cruiser Convertible Forum 4 18 Nov 2011 01:19 pm
groaning ? lunyty Wheels, Tires, Suspension 1 10 Feb 2011 11:50 am
