Swap 2001 2.4L Engine into Newer body
Old 11 Jul 2014, 03:01 pm
slight_leak's Avatar
Default Swap 2001 2.4L Engine into Newer body
We have a 2001 PT Cruiser 2.4l base model. Just wrecked it and the insurance wants to total it. Replacement engine is still under warranty.
Idea is to find a newer PT with a bad engine and "upgrade" to a limited or something better.
Anyone know what is the max year you can go UP from the 2001??
Thanks
Old 11 Jul 2014, 03:18 pm
LionPT's Avatar
Default Re: Swap 2001 2.4L Engine into Newer body
2005 I believe, 2006-2010 has the can bus installed & wouldn't be compatible electrically.
Old 11 Jul 2014, 03:54 pm
cruserdad1976's Avatar
actually thans not right its like 01-02 they changed the egr or something like that so relaly unless you are willing to do a lot of modding I think its like a 03 uptown or nitro can tell you exactally what years will fit
Busted_PT likes this.
Old 11 Jul 2014, 04:41 pm
Handy_Cruiser's Avatar
The crank sensor on the 2001 and 2002 engines are very different from the 2003 and newer PT engines and are not interchangeable. And these early sensors do not talk to the PSU in the same way the later ones do. It's much more of a difference than just sensor position. The crankshaft and crank sensor wheel are different too. There is no viable way (short of some very complex electrical engineering) to mate the early 2001 and 2002 engine up with a 2003 or later PT electrical system.
And to answer your questions directly, you can likely fit your 2001 engine in a 2002 PT. But not newer. For the EGR difference between the 2001 and 2002 (most 2002 PT's have no EGR valve), you can likely just leave the EGR on the 2001 engine. In a 2002 PT, there will just be nothing to plug the EGR sensor into. Everything will likely work fine like that. You just may not know if the EGR valve goes bad. And they don't go bad often.
2003 and Newer PT Engine
2001 and 2002 PT Engine
Old 11 Jul 2014, 05:57 pm
You can go 03 t0 05 Or even newer if you change everything like wiring computer, everything. Other wise 02 is the limit.
Old 11 Jul 2014, 06:10 pm
Okay everyone thanks for the info. I'm gonna get busy finding a nice 2002 with a blown engine to rescue. Our 2001 base model is not very nice anyway.
Old 11 Jul 2014, 07:18 pm
[/IMG]
My 2002 had EGR.
Old 11 Jul 2014, 10:46 pm
Originally Posted by quicksilverdon View Post
My 2002 had EGR.
Yep.
I'm sure there's some variability with all this "common knowledge".
Old 11 Jul 2014, 10:48 pm
There's no shame in a 2001 Limited either. The 2001 PT has a few features usually not seen in the later PT's.
Old 12 Jul 2014, 05:15 am
Your opinion is not biased in any way is it?
We are open to a 2001 just finding the right one that has not been abused is the hard part.
What features does the 2001 have that the late models do not?
2001 Engine swap mastifffreak Tech & Performance Forum 19 18 Feb 2014 10:35 am
Engine swap 2001 to 2007 boerter Tech & Performance Forum 7 16 Feb 2014 11:08 am
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
Can I do this engine swap 2003 to 2001 jrr344 Tech & Performance Forum 10 11 Mar 2012 02:12 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
