Knocking sound on driver side
Like Tree4Likes
  • 1 Post By soyomb
  • 2 Post By JoeX
  • 1 Post By quicksilverdon
Old 11 Jul 2014, 04:05 pm
Default Knocking sound on driver side
Every time car hits a pothole, I hear this knocking sound coming from the driver side front tire, so strong that you can feel it all the way to the steering wheel.....lifted the front wheel tire with a jack this morning to inspect it but can't see any loose end....CVT and steering column seem fine & intact.....no effect on accelaration or normal runs on flats....btw, brake rotor was replaced a month ago.....any ideas?
Old 11 Jul 2014, 04:28 pm
Default Re: Knocking sound on driver side
check the swaybar bushings and/or tie rods.
ColTED likes this.
2016 Kia Soul Plus Black
Old 11 Jul 2014, 06:26 pm
I would guess its the bottom ball joint in the Lower Control Arm, but there are different points that make noise in the PT Cruiser suspension.
Upper bearing mount, Bushings in the Lower Control arm, sway bar bushings and mounting points to the lower control arm.
I left these two for last because if worn enough can cause you to loose control if either pop out of their socket. Please have them checked for safety sake.
Tyrod, Botom Ball joint, inner tyrod
You can probably search Youtube and find a video on how to check each one
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Jul 2014, 07:13 pm
I agree. I think Lower control arm bushings are the first to go.
ColTED likes this.
Old 12 Jul 2014, 12:27 am
thank you for all your tips, I'll bring it to the shop tomorrow to be checked by mechanic...
Old 12 Jul 2014, 12:17 pm
Turned out that it was just the left sway bar rubber bushing....it not just worn out, it's totally gone thus the clunking sound of metal to metal contact every time left tire hits a pothole......my trusty Viet shop replaced both L & R bushings for a measly $60 labor inclusive....
01 Cruiser Knocking Sound?? ag4bucs Wheels, Tires, Suspension 6 22 Mar 2013 11:50 pm
knocking sound jinky Tech & Performance Forum 13 24 Dec 2012 12:06 pm
Knocking sound from front end Lojo61377 Wheels, Tires, Suspension 3 03 Apr 2012 02:59 pm
Knocking from rear driver side wheel when braking Cartmansnuts Wheels, Tires, Suspension 12 23 Mar 2012 10:00 am
knocking sound mykelzy Wheels, Tires, Suspension 6 23 Sep 2004 09:51 am
