How do I get this gear off?
Old 16 Jul 2014, 03:47 pm
domsob1974's Avatar
Default How do I get this gear off?
Hi,
I have a 2001 Pt Cruiser 2.4L NA. I had a rod knocking, and am rebuilding the motor. I have the crank out, but I can't seem to get the gear off of it. Any suggestions, or techniques, would be greatly appreciated. Here are a couple of pictures of the gear that I am talking about.
Thanks in Advance
Old 16 Jul 2014, 05:15 pm
Default Re: How do I get this gear off?
Most likely presses off. Can you just leave it on.? Someone else may have a better answer soon.
Old 16 Jul 2014, 05:33 pm
domsob1974's Avatar
I am putting in a new crankshaft and wanted to use the gear. I can order another sprocket for $10, but it is holding me up to rebuild and get it back in. Yes, i know you can eliminate it for more HP at a cost of more vibration, but I don't think my 70 yr. old mother cares much for +10hp lol.
Old 16 Jul 2014, 05:35 pm
domsob1974's Avatar
I found this info online:
Underneath the pump you will see the driving shaft sprocket. Take the sturdy screwdrivers and slowly work away the sprocket. Do this gently as to not mess with the crank geometry and create crankshaft-end play. If this happens you will run a greater tendency to spin some rod and main bearing. 5. With the sprocket loose remove the shaft carrier in one complete piece along with shaft driving sprocket altogether. The carrier is removed by unscrewing the main bolts that connect the carrier to the bedplate.
It comes from Balance Shaft Removal How-To, but so far "working" it with a screwdriver isn't "working" LOL
Old 16 Jul 2014, 06:35 pm
You loose low end torque as well. Pm Nitro_PT. He will know.
Old 16 Jul 2014, 07:26 pm
See if you can rent a hub puller with real long "fingers".
Old 16 Jul 2014, 07:30 pm
As the teeth look quite worn I my self would install new
Old 17 Jul 2014, 10:25 am
domsob1974's Avatar
I just ended up ordering a new one. $19.12 inc. shipping is less of a headache then trying to find a press or long tooth puller. Thanks!!!!
Old 17 Jul 2014, 10:56 am
Good choice.
Old 17 Jul 2014, 12:44 pm
I was curious about the excessive ware. I didn't see anything to be concerned with. But how do you plan to get the new one on?
No 2nd gear!! (please help) UnFoRgIvEn907 Tech & Performance Forum 1 05 May 2013 07:08 am
car will not gear up :( kerenmantilla25 General PT Cruiser Discussions 9 30 Jun 2012 06:55 pm
3rd gear FanDroid General Turbo Discussions 3 28 Nov 2011 04:21 am
no 3 or 4 gear JaviPTGT Tech & Performance Forum 11 03 Apr 2011 02:02 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
