HELP! Replace Motor Mounts 2003 Base model
  • 1 Post By ColTED
Old 18 Jul 2014, 12:14 pm
Question HELP! Replace Motor Mounts 2003 Base model
PT Forum,
I could use some help with replacing all of the motor mounts on my brides 2003 PT Cruiser base model with standard transmission.
Please advise on how to replace all motor mounts and what parts manufacture you recommend. Plus maybe where you would purchase.
If I understand correctly there is four motor mounts. Two "torque struts" and a right and left main motor mounts.
The reason why I am asking is because our local oil & lube pointed out that the upper torque strut was s shot.... no worky worky... and to replace all four would be a cool $1000.
I don't have $1000. for motor mounts but I do have skills. Plus hopefully some friends here.
I have not inspected the remaining mounts.
Any advice would be appreciated.
thank you my PT Cruiser forum in advance.
Old 18 Jul 2014, 01:03 pm
Default Re: HELP! Replace Motor Mounts 2003 Base model
Jaimez likes this.
Old 18 Jul 2014, 01:18 pm
Most likely you only need to worry with the upper and lower torque struts. The proper setup procedure is a must. It's not rocket science. Probably show this in the video posted. I'll look and post back if not. eBay or Rockauto should get you the best price. $40 for the pare should be a good average.
Old 19 Jul 2014, 09:15 am
While the mechanical steps to actually change the lower mount are functional in the Video. The set up procedure was left out intirelly. Top was probobly bad as well. Anyway you leave the bottom loose and loosen the top and jacking on the front edge of the oil pan (with a wooden block) to tilt the motor to the rear until you get the 3.7" or 119mm adjustment and tighten everything down. This should minize vibration and premature failure of the mounts
Old 19 Jul 2014, 10:48 am
32highboy's Avatar
119 mm is 4.7 inches
Old 19 Jul 2014, 05:26 pm
Oops your right. Thank you for chatching that. Just did it the other day and still typed it wrong. Lol
Tags
motor mount
2003 Chrysler PT Cruiser radiator fan motor 2.4 turbo gt model $300 (over $600 new) turbogodstoyscom Classifieds: For Sale/Trade 1 23 Aug 2013 09:07 am
2003 pt base model vibration between 2nd and 1st gear peterduke General PT Cruiser Discussions 0 05 Sep 2012 01:25 pm
converting base model to gt? jamie_hildebrand General Turbo Discussions 6 08 Jun 2012 09:06 pm
2003 PT base model for sale hollywoodknight Classifieds: For Sale/Trade 12 18 Feb 2011 12:51 am
Parting Out 2005 PT Cruiser base base model taftboys Classifieds: For Sale/Trade 9 07 Oct 2010 07:13 pm
