High sipped fan not working when AC on but will work when the engine warms up.
Like Tree4Likes
Old 18 Jul 2014, 08:09 pm
Default High sipped fan not working when AC on but will work when the engine warms up.
Finally got my daughter 04 Cruiser's AC fixed, but the high speed fan doesn't come on when the Account is on. It does however come on when the engine reach the temp to make the fan come on. I swapped relays and that didn't work. I know the low speed doesn't work on the fan. What should I check to get the high speed at least to work with the AC on.
Bob
Old 18 Jul 2014, 08:21 pm
Default Re: High sipped fan not working when AC on but will work when the engine warms up.
Have you jumped the fan to see if the fan is bad. If the proves the fan is bad. Will need to replace.
Old 18 Jul 2014, 08:42 pm
I disconnected the electrical connector just below the fan and jumped the middle (ground) to each side. The high speed kicked right on, but there was nothing from the low side.
Old 18 Jul 2014, 09:01 pm
Need to buy a fan. Common to loose only one speed.
Old 20 Jul 2014, 03:25 pm
Still don't understand circuitry of stock NA PT fans. All I have tested here do not have hi speed or low speed aires and central ground, rather they have two low speed wires and a central ground. When either wire is powered fan spins at low speed, when BOTH wires are powered the fan spins at high speed.
Old 20 Jul 2014, 03:35 pm
Here's the schematic for the fan (for the 2001) and there is a high and low speed circuitry for each speed.
boonie2 likes this.
Old 20 Jul 2014, 05:11 pm
My fan works on high speed when I power the high speed connector, but no low speed when I power that side of the connector.
Has anyone ever determined on the 2004 if the high or low speed fan runs when the AC is operating.
Bob
Old 20 Jul 2014, 05:21 pm
LionPT's Avatar
When you turn of the A/C, does the fan come on..??
Old 20 Jul 2014, 05:34 pm
Bob
Bob, we had this discussion many times and there' seems to be a difference of opinion on your question. My LOW speed fan comes on when the A/C is turned on, others have reported the HIGH speed fan coming on with the A/C. Not sure who is right or it might have something to do with the year of the PT.
Old 21 Jul 2014, 08:02 am
Crewzin,
So, if what's been posted about the 04 Cruiser that the high speed fan comes on when the AC is running. And my high speed does work, because it's come on when the engine gets warm enough, why would it not come on when the AC is on. What makes the fan come on when the AC is on? A sensor or the PCM?
Bob
2004 High Beam's not working?? jrunner Interior Accessories Forum 3 03 Oct 2013 11:22 am
Radiator Shakes Once Engine Warms Up soundofbread General PT Cruiser Discussions 5 24 Sep 2013 02:34 pm
PT 2002 LOW AND HIGH SPEED NOT WORKING sliver Tech & Performance Forum 9 10 May 2012 10:53 pm
Rad fan not working after work was done on vehicle ddash General PT Cruiser Discussions 5 29 Sep 2010 05:29 pm
Do those high tech air intake and filter kits work? mikk66 Tech & Performance Forum 6 28 Aug 2009 05:14 pm
