help blowing white smoke
Like Tree2Likes
  #11 (permalink)
Old 19 Jul 2014, 01:01 am
Default Re: help blowing white smoke
"KOOL" looking Pt btw. Like to see the pictures of the ACCEL coil and new plug wires!
  #12 (permalink)
Old 19 Jul 2014, 06:07 am
i took them off because i thought they were the problem. i get this ceared up i'll put them back.
the MAP sensor should be pointed into the airbox right?
  #13 (permalink)
Old 19 Jul 2014, 06:48 am
just took it for a ride, let it get to op temp, no smoke. slight smell or burnt oil/gas but thats it with no stumble. does the pcv really have that much "authority" over the motors function? i cleaned it spotless last night (ball kind). still gonna keep a close watch but thanks to all for there help and .02cents.
  #14 (permalink)
Old 19 Jul 2014, 07:34 am
Well, PCV is surely an easy and cheap fix.
Strange it coincided with you changing plug wires.
  #15 (permalink)
Old 19 Jul 2014, 08:14 pm
that was my thought too. too high a resistance in them?there b&b suppression wires
Amazon.com: B & B Manufacturing Corporation S4-58302 8mm Suppressor Spark Plug Wire Set: Automotive
  #16 (permalink)
Old 19 Jul 2014, 08:25 pm
The spark plugs wire can be effective on a PT + 2000ohms per FT. The wires are less than a foot. Most performance wires are less than 100ohms per foot and low quality wire are generally in the 500-900ohms per foot range.
What all this means is generally speaking most anything on a PT Cruiser because of less than a foot of wire from the coil to the spark plug.
But I like MSD Don likes CRANE(?) etc., etc., etc.
  #17 (permalink)
Old 19 Jul 2014, 08:30 pm
when i cleaned the pcv valve,it was gunked and the ball was sticking. i actually cleaned it in the kitchen sink with dish soap til it moved freely. still cant believe one cheap little valve.
bet i jarred it into a sticky stuck position moving stuff around the bay.
took the wife and kids to the zoo/amusement park...30 min.....not a hiccup
  #18 (permalink)
Old 19 Jul 2014, 09:31 pm
Nice! Glad to hear you got it resolved!
Also you have an understanding wife as I do. Some auto parts needs to be cleaned in the kitchen. I use the dish washer often for cleaning carburetors, turbo housings, etc. i do naturally pre clean the oil or grease and such before using the dish washer.
  #19 (permalink)
Old 19 Jul 2014, 09:40 pm
LionPT's Avatar
I've always used the dish machine for air cleaners, valve covers & misc parts...but I've never run a carburetor through it...not sure that I ever would TBO.
Dish machine also works good on computer keyboards...just turn heat off.
  #20 (permalink)
Old 20 Jul 2014, 12:12 am
I should have been more clear..... Hahaha not assembled carburetors but parts of them. LOL
Think about it for a minute. When you dis assemble a carburetor and clean all the small ports and blow it out the carb cleaner remains. If you run bodies and metering plates through the dish washer using cascade and heat dry the detergent lowers the surface tension of the water cleaning all the parts better than with carb cleaner and the heat completley dries them of any remaining water. I had a dish washer in the machine shop for years and rebuilt hundreds of carbs for myself and customers everything from Holleys , DCOEs, Kiehn, to electrons.
Now you should see what I use the kitchen oven for baking!
LOL go look at early postings on Nitro's PT Cruiser thread!
Smoking bad on start up only.White smoke. giovanna55 Turbo Performance 37 10 May 2014 02:25 am
White smoke on start up Margo Tech & Performance Forum 16 28 Apr 2013 01:39 pm
White Smoke from Exhaust clickhere4dawn Tech & Performance Forum 15 15 Oct 2012 06:09 pm
white smoke drewmilk12 Midwest PT Forum 11 31 Aug 2012 01:13 pm
White Smoke from Exhaust susiegtx General Turbo Discussions 8 14 Dec 2011 06:08 pm
